Step response of a first order system
The discussion focuses on finding the unit step response of two first-order transfer functions: G(s) = 4/(s + 4) and G(s) = 2/(0.2s + 1). The step response for the first function is correctly derived as c(t) = 1 - e^(-4t). For the second function, the user transformed G(s) into the required form by dividing the numerator and denominator by 0.2, resulting in G(s) = 10/(s + 5). The final step response is confirmed as c(t) = 2[1 - e^(-5t)], utilizing the linearity of the Laplace transform.
  • Understanding of first-order systems in control theory
  • Familiarity with Laplace transforms and their properties
  • Knowledge of transfer functions and their representations
  • Ability to perform inverse Laplace transforms
  • Study the properties of Laplace transforms in detail
  • Learn about the stability analysis of first-order systems
  • Explore the application of transfer functions in control systems
  • Investigate the effects of different input signals on system responses
Students in engineering, control system designers, and anyone studying dynamic system responses will benefit from this discussion.
VinnyCee
Find the unit step response of the transfer function...
a) [tex]G(s)\,=\,\frac{4}{s\,+\,4}[/tex]
b) [tex]G(s)\,=\,\frac{2}{0.2s\,+\,1}[/tex]
General first order step response equation...
[tex]C(s)\,=\,R(s)\,G(s)\,=\,\frac{a}{s(s\,+\,a)}[/tex], where [tex]R(s)\,=\,\frac{1}{s}[/tex]
then do an inverse Laplace transform...
[tex]c(t)\,=\,1\,-\,e^{-at}[/tex]
Part a) is simple enough. I just plugged into formula above and got [tex]c(t)\,=\,1\,-\,e^{-4t}[/tex]
However, part b) is where I am confused. To get the G(s) into the form needed (i.e. ~ [itex]\frac{a}{s\,+\,a}[/itex]), I divided both the numerator and denominator by 0.2...
[tex]G(s)\,=\,\frac{2}{0.2s\,+\,1}\,=\,\frac{10}{s\,+\,5}\,=\,2\left(\frac{5}{s\,+\,5}\right)[/tex]
But now the form is not exactly as needed in the first order system equations. What do I do?
I tried taking out a 2 from the numerator, and got an answer, just not sure if it's right though.
Is this right for part b)...
[tex]c(t)\,=\,2\,\left[1\,-\,e^{-5t}\right][/tex]
That's right, remember that the Laplace transform is a linear operation. If f(t) has a Laplace transform of F(s), then a*f(t) has a Laplace transform of a*F(s). Assuming "a" is a scalar quantity. The same linearity is true for inverse Laplace transforms.
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 0 ·
