Phase Transitions and Chemical Potential
The discussion revolves around the concept of phase transitions in thermodynamics, specifically focusing on the role of chemical potential in these transitions. Participants explore whether phase transitions are always present in systems when varying conditions such as pressure and temperature, and they seek to understand the mechanisms that drive these transitions.
  • Mr.Fogg questions whether there are systems that do not undergo phase transitions when changing variables like pressure or temperature.
  • Some participants propose that when the chemical potential is equal in both phases, it costs no energy to move particles between phases, suggesting a balance at the transition point.
  • Others argue that systems generally transition between solid, liquid, and gas states depending on temperature and pressure, indicating that phase transitions are common.
  • Mr.Fogg raises questions about the forces that drive phase changes, particularly when heating or increasing pressure, and whether these changes can be understood through the lens of Gibbs Free Energy.
  • There is a discussion on the atomistic perspective of phase transitions, with some participants noting that atoms are constantly evaporating and condensing, and equilibrium is reached when chemical potentials are equal.
  • Mr.Fogg expresses uncertainty about calculating Gibbs Free Energy for different phases and how to handle entropy in these calculations.
Participants generally agree that phase transitions are influenced by chemical potential and Gibbs Free Energy, but there is no consensus on whether all systems experience phase transitions under varying conditions. The discussion remains unresolved regarding the specific mechanisms and conditions that lead to phase changes.
Participants express uncertainty about the conditions under which phase transitions occur and the implications of Gibbs Free Energy and entropy in predicting these transitions. There are references to the atomistic behavior of particles during phase changes, but these concepts are not fully resolved.
Phileas.Fogg
Hello,
right now, I am learning thermodynamics with Reichl: "A modern Course in Statistical Physics"
In chapter 3.C page 100 "classification of phase transitions", the text says:
"As we change the independent intensive variables (p, T, x_1,... ,x_l) of a system,
we reach values of the variables for which a phase change can occur. At such
points the chemical potentials (which are functions only of intensive variables)
of the phases must be equal and the phases can coexist."
I wonder, if there are systems with no phase transition at all. Or is there always a phase transition, if I change for example pressure, or temperature, or the mole fractions of particles of type i ?
What does the chemical potential have to do with the phase transition? I know, that it is equal in both phases at the transition point, but how does the phase transition occur? What forces the system to change it's phase? What does the chemical potential of the system do before the transition?
I hope you can help me.
Regards,
Mr.Fogg
When the chemical potential is equal in both phases, then it costs no (free) energy (or enthalpy) to move a particle from one phase to the other. When they are not equal, then you can gain energy by moving particles from the phase with lower potential to the one with higher chemical potential (don't try to nail me down on the sign here) until you eventually reach equilibrium.
When you plot the chemical potential of your phases as a function of e.g. temperature at p fixed, the curves for the different phases cross at the transition temperature. In principle, nothing spectacular happens, often you can continue on a single curve beyond the crossing point, e.g. you can supercool liquid water below 0 degrees centigrade.
The classical example to study a phase transition is the van der Waals gas. You can find for the van der Waals equation a phase transition analytically from the condition that p1=p2 and mu1=mu2.
Thanks DrDu,
Since in equilibrium the Gibbs' Free Energy is a minimum, the system should prefer the lower chemical potential. So this should be correct, to gain energy from lower to higher potential.
Mr.Fogg
Can anybody answer my other questions?
Basically all systems become solid or (super-)liquid near absolute zero of temperature and become gasses at sufficiently high temperatures. So there is allways some phase transition.
Thanks,
I understand now, one could explain it by taking a look at the p-T diagram.
[tex]\lim_{T \to 0} \left( \frac{\partial p}{\partial T} \right)_V = 0[/tex]
The coexistence curve starts at zero p and T and the fusion curve goes to infinity. So there must be a temperature in between, where a phase transition occurs. At least solid <-> liquid and solid <-> gas should change the phase. The vaporization curve terminates at the critical point.
But what forces the system to change it's phase? For example, when I heat it up? Or if I increase the pressure?
Regard,
Mr.Fogg
Systems tend to proceed toward states with the lowest energy; it's a consequence of the Second Law. But we need to consider the correct energy potential; for systems at constant temperature and pressure, it's the Gibbs free energy that's minimized.
Or are you asking what happens atomistically, e.g., why more atoms would evaporate from a liquid's surface rather than condense there?
Okay, I see. So from the Second Law, we get for the Gibbs Free Energy [tex]d(U+pV -TS) < 0 \Rightarrow dU +pdV - TdS < 0[/tex].
And to deal with the change in entropy, we take the Clausius (In)equation [tex]dS = \frac{\delta Q}{T}[/tex]
The system prefers the state with lower Gibbs Free Energy. So I have to calculate the Gibbs Free Energy for each phase with G = U + pV - TS and then I know, where the system will transfer to? Or is there another possibility to predict that? How do I handle the entropy in this case? I think, one only can measure changes in entropy, not an absolute entropy?
Could You explain that? Maybe it helps me to understand.
Regards,
Mr.Fogg
Right, that's the criterion for phase equilibrium at constant temperature and pressure. The atomistic view is that (between a liquid and gas, for example), atoms are always evaporating and condensing, and the rates are equal when the chemical potentials (i.e., the partial molar Gibbs free energies) of each phase are equal.
  • · Replies 29 ·
