Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > General Engineering
Notices
Reply
image How to measure recoil force? Share It Thread Tools Search this Thread image
Old Feb10-10, 09:05 AM                  #1
protector
protector is Offline:
Hi
I'm interested in measuring the recoil force of a weapon.
Anyone got any ideas om how to go about doing this? I was thinking of using a load cell mounted to the weapon in the horizontal plane, but at the same time the weapon needs to operate more or less freely, which will be difficult with the weapon mounted to a load cell (not very much travel there).
I was also thinking of mounting a spring between the load cell and weapon to allow for more travel of the weapon, and this is more or less this idea I'm working on now. Will this work and give me the right measurement? Will I need to know the exact spring constant and distance travelled and do some calculations, or will the load cell reading be the correct one regardless of the spring?
Old Feb10-10, 11:13 AM                  #2
FredGarvin
FredGarvin's Avatar
FredGarvin is Offline:
Recognitions:
PF Contributor PF Contributor
Re: How to measure recoil force?
You don't need to know the spring constant. You are measuring the force! If you were just measuring the deflection, then you would need it.
I would say the spring is a better way to go. The only little tough part is to make sure you have something guiding and holding the weapon so that it only moves linearly. This also assumes that you know the actual path the recoil is taking, but I would think any guess to that would be pretty close and not induce too much experimental error.
Old Feb10-10, 01:16 PM                  #3
Doug Huffman
Doug Huffman is Offline:
Yes, measuring the force with a dynamometer is the way to go. But watch the impedance and time related values because you want the instantaneous force and that's a bit harder to get.
If you're a shooter and thinking of recoil then you need to read up on impetus and momentum and stuff.
Old Feb10-10, 04:34 PM                  #4
protector
I've got a fixture to mount the weapon in making sure I get linear movement (horizontal).
image image
Reply
Thread Tools
Similar Threads for: How to measure recoil force?
Thread Thread Starter Forum Replies Last Post
Measure force of impact joanneneil Classical Physics 3 Nov22-09 08:15 AM
Calculate the average recoil force exerted on the weapon during that burst. zhuyilun Introductory Physics 3 Nov1-09 03:58 PM
HELP: How would you measure the force of an expolsion? Kool-Aid General Physics 7 Aug28-09 10:42 PM
Finding recoil velocity only given force and firing velocity junkmonk Introductory Physics 3 Mar28-09 11:08 PM
How to measure the lack of external force during free fall? Bob Walance Special & General Relativity 6 Sep20-07 07:35 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
