| Thread Closed |
Parallel Plate Capacitor Spacing Question |
Share Thread | Thread Tools |
| Feb10-10, 01:19 PM | #1 |
If the length and width of each plate of a parallel plate capacitor were doubled, and the spacing between the plates was also doubled, by what factor does the capacitance change?
I know that increasing the length and width of a plate increases its capacitance, and I thought that it was directly proportional, but I'm not sure about spacing the plates... it's an interesting question... |
| Feb10-10, 01:24 PM | #2 |
Mentor
| Feb10-10, 06:14 PM | #3 |
Is it e*Area/distance?
| Feb10-10, 06:22 PM | #4 |
Mentor
Parallel Plate Capacitor Spacing QuestionThis simple equation is used a lot in capacitor calculations, but keep in mind that it is simplified from the more accurate equation. This equation ignores the fringing field at the edges of the parallel plate capacitor. For a cap with lots of area A compared to the spacing distance d, this is a fine approximation. But if the distance d is, say 1/10 of the length of one of the sides of the cap plate, then you will measure a higher C than you calculated by probably around 10% or so. But this basic equation should be fine for your conceptual question. So what's the answer? |
| Feb10-10, 06:28 PM | #5 |
The capacitance increases by a factor of 2, because 2*2/2=2.
I feel stupid. Thanks for the help.
| Feb10-10, 06:29 PM | #6 |
Mentor
Correct. No reason to feel that way, BTW. We all had to learn to use that equation (and learn its limitations) at some point.
| Apr14-10, 12:39 AM | #7 |
what if the distance between the plates is much larger than the diameter of the parallel plates?? how do we then calculate the capacitance???
| Apr14-10, 12:48 AM | #8 |
Mentor
You tell us. That's how it works around here... |
| Apr14-10, 12:54 AM | #9 |
i looked around a lot..all i know is
Decreasing the separation of the plates, decreases the voltage of the capacitor since the electric-field is not affected by the distance between the plates. The voltage on the capacitor is V=Ed. Therefore the voltage increases. For a constant charge, Q, C=Q/V =Q/Ed and vice-versa..then why cant the same formula still remain applicable??? |
| Apr14-10, 01:09 AM | #10 |
i will be really glad if u can help me with this...we am working on a project where the calculation of resonant frequency is very important for which we require...
| Apr14-10, 11:34 AM | #11 |
Mentor
| Thread Closed |
| Tags |
| capacitance, capacitor, parallel, plate, spacing |
| Thread Tools | |
Similar Threads for: Parallel Plate Capacitor Spacing Question
| Simple Parallel Plate Capacitor Question | Classical Physics | 3 | ||
| Parallel-Plate Capacitor Question | Introductory Physics Homework | 1 | ||
| Parallel Plate Capacitor- Intro Physics Question | Advanced Physics Homework | 6 | ||
| Simple Parallel-Plate Capacitor Question...please HeLP!!! | Introductory Physics Homework | 6 | ||
| parallel plate capacitor capcitance question? | Introductory Physics Homework | 5 | ||
