Surface area of smooth parametric surface
The discussion centers on calculating the surface area of the portion of the surface defined by the equation y = x², constrained by 0 ≤ z ≤ x ≤ 2. The correct parameterization for this surface is given as R(x, z) = ⟨x, x², z⟩, with the domain being a triangle in the xz-plane. The initial attempts using trigonometric functions were deemed unnecessary, as the surface is a cylindrical parabola in the first octant. The final solution requires integrating over the specified domain to find the surface area.
  • Understanding of parametric equations in three-dimensional space
  • Familiarity with surface area calculations for parametric surfaces
  • Knowledge of vector calculus, specifically cross products
  • Basic integration techniques in multivariable calculus
  • Study the calculation of surface areas for parametric surfaces in vector calculus
  • Learn about the application of the cross product in determining surface area
  • Explore parameterization techniques for different types of surfaces
  • Review integration over triangular domains in multivariable calculus
Students and educators in calculus, particularly those focusing on multivariable calculus and surface area calculations, as well as professionals working with parametric surfaces in engineering and physics.
zzheng
Sorry I am new to the forum, I don't know how to type in the integrals and stuff.
Let S be the portion of the surface y = x2 where 0 <= z <= X <= 2. Compute the surface area of S.
r(u,v) = x(u,v)i + y(u,v)j + z(u,v)k
A(S) = integral ru X rv dA
My first attempt I did: x = ucosv, y = u2cos2v, and z = ucosv where 0<= u <= 2 and 0 <= v <= 2pi
when I was doing ru X rv, got a lot of sines and cosines but everything canceled out at the end and became 0.
Then I just decided to use x = x, and y = x2 where x is from 0 to 2.
but then ry turns out to be 0.
I am not sure how I would do this, most of the problems I have done are z as a function of x and y, but this case z is given but I don't know what to do with it.
Could some one please help me with this? Thank you for your help in advance.
Unless you are describing a surface of revolution, which you haven't described, I don't see why you would involve trig functions in the parameterization. The surface y = x2 is a cylindrical parabola standing vertically on the xy plane. If I understand your description correctly, you are talking about that portion of the cylindrical surface in the first octant under the plane z = x.
If I'm correct, the natural paramaterization would be to use x and z:
[tex]\vec R(x,z) = \langle x,x^2,z\rangle[/tex]
and your domain is a triangle in the xz plane. Try that.
