Is a change in earth's surface gravity detectable?
The discussion revolves around the possibility of detecting changes in Earth's surface gravity using non-inertial measurements. Participants explore various methods, including laser interferometry and gravitational redshift, while questioning the feasibility and implications of such measurements.
  • One participant questions whether a brief change in Earth's gravity could be detected using a laser interferometer, specifically if the interference pattern would shift due to gravity changes.
  • Another participant suggests that changes in gravitational redshift could be a method to detect variations in gravity, referencing the frequency change of light as it moves through a gravitational field.
  • A different viewpoint argues that using a laser interferometer would ultimately involve inertial measurements, as the measurement of distance is influenced by the forces acting on the physical components of the setup.
  • Some participants discuss the implications of increased gravity on spacetime curvature, suggesting that it would affect the distance traveled by light and thus alter the interference pattern observed.
  • One participant raises the point that detecting changes in gravitational strength without inertial measurements may be impossible, questioning the nature of the proposed methods.
  • Another participant emphasizes the theoretical dependence of changes in fundamental properties (like particle masses and clock rates) on the gravitational field, indicating that under General Relativity, gravity changes would not occur without changes to Earth's mass or radius.
  • Concerns are raised about the practicality of existing methods, such as the Pound-Rebka experiment, in creating a compact accelerometer for detecting gravitational changes.
Participants express differing opinions on the feasibility of detecting changes in gravity without inertial measurements. While some propose methods like gravitational redshift, others argue that these methods inherently involve inertial measurements, leading to an unresolved debate.
Limitations include the dependence on theoretical frameworks, such as General Relativity, and the practical challenges of implementing proposed measurement techniques. The discussion does not resolve the complexities surrounding the detection of gravitational changes.
Creator
Since my question relates to gravitational field I've placed it here under Gen. Rel. section to encourage more knowledgeable ideas & responses from those who are gravitationally astute.
Here's my question:
If the Earth were to increase its gravitational field at the surface (for whatever reason), would one be able to detect that increase with non-inertial measurements?
I mean, would one be able to detect it with methods other than weight changes, mass or inertial changes (like gravitometers), etc.?
For example. to be more specific, is it possible to detect a brief change in Earth's gravity field with a laser interferometer? Let's say an interferometer that is oriented with one arm pointing upward (vertical) for a hundred meters, and the other arm placed horizontal to the Earth's surface for 100 meters? A laser source of specific frequency located near the vertex passes light thru a beam splitter, reflects it off the end of each arm and back to the vertex where a detector registers the interferebnce pattern, (as in a usual interferometric setup).
Let us assume for simplicity the field is constant for the vertical distance of the vertical arm (no field gradient) and equal to the field in the horizontal direction. Now the Earth's gravity field changes abruptly for, say, a few seconds or so while we are monitoring the interference pattern. Assuming the interferometer is sensitive enough, will the gravity change be detectable? Will there be a shift in the pattern? Why or why not? Does the velocity of light change with a field change? Does the frequency change so as to make the gravity variation detectable? :confused:
Can someone interested enough give me some logical supporting opinions please?
Creator
Creator said:
Here's my question:
I guess you could look for changed in gravitational redshift, i.e. the change in frequency of light as it climbs up the gravitational field.
Pete
I think that this measurement would, in practice, wind up being in the class of inertial measurement that you want to avoid. You can think of the laser beam measurement of distance as being a stiff rod - as stiff as anything ever gets (there's no such thing as a rigid body in relativity). So what you'd be measuring with your interferometer is the difference in stiffness between your laser beam, and your physical construct, i.e. you'd be measuring the displacement due to the change in force on a spring, the spring being the physical arm of your interferometer, which would be less rigid than your laser beam.
Im not that knowledgeable with inferometers, but if you were to increase the Earth's gravity, no matter where you were, that would in turn bend space time a little more and would make oblects traveling in the curved spacetime seem like they are traveling a longer distance. If I remember correctly, the accounted distance is [tex]D = m/3c^2[/tex] where [tex]m = mass \ D = extra \ distance \ and \ c = speed of light[/tex] This extra gravity added to the Earth would elongate the distance traveled by the laser beam and would in turn give you a different interference pattern.
To answer Creator's general question, yes, and pmb_phy got the obvious method - gravitational redshift. Gravitational time dilation would be another obvious method.
In principle, all ( :wink: ) you'd need to do would be to repeat the classic 1960's Pound, Rebka and Snyder redshift experiment, and the 1976 Scout rocket time dilation one. Some background here.
Of course, you'd have to find a way to increase the sensitivity by ~>3 OOM :eek:
I don't see this. If you changed the potential energy of the whole setup, you could change the metric coefficeints, I suppose, i.e. the length of the meter would be different.
But let's consider a thought experiment. Let's measure the length of a 1 meter bar with a laser. Now let's fly the bar into outer space, where g_00, g_11, etc are different, and measure the length again with a laser. We will measure the exact same length we measured on the ground, because the metric change will affect the bar and the interferometer equally.
Apparently, it is impossible to detect a change in Earth's gravitational strength without inertial measurements, right? All of the methods presented at least involve an intertial measurement...right?
Would you please explain how a measurement of the gravitational redshift involves an inertial measurement?
A good question, the next question is, "What would change (fundamental particle masses, lengths of rulers, clock rates) with the gravitational field?" The answer to which is theory dependent. If that theory is GR then you don't expect the gravitational field to change in the first place, unless the Earth's mass or radius changes, due to a massive impact for example.
Takin the empirical approach, I did a quick google search for accelerometers. There were several references for laser gyro's, but none for laser linear accelerometers. The wikipedia link was representative
wiki-link
So far I haven't found any reference to a linear laser accelerometer - linear accelerometers all seem to use pendulums, or hold the position of a mass steady and measure the forces needed to do this (like a gravimeter).
However, the redshift method should work in principle. Experiments I've read about had to use a rather exotic method (the Mossbauer effect) over a long distance (a tower) to measure this, though - the Pound & Rebka experiment. Not something that would make a compact accelerometer, in other words.
  • · Replies 22 ·
  • · Replies 16 ·
