How to Write Powers in Text Format on Websites?
  • Thread starter Thread starter Gringo123
The discussion revolves around how to write powers in text format on websites, specifically focusing on the use of formatting options available on the forum.
  • Exploratory, Conceptual clarification, Mixed
  • Participants share various methods for writing powers, including using specific formatting buttons and LaTeX syntax. Some express preferences for different methods and discuss the flexibility of these options.
Several participants have provided guidance on how to use different formatting options, including the use of the 'X^2' button and LaTeX commands. There appears to be a productive exchange of ideas, with multiple methods being explored without a clear consensus on a single preferred approach.
Some participants mention the need for both opening and closing tags when using certain formatting options, indicating a potential area of confusion. There is also a reference to the limitations of the forum's formatting capabilities compared to other software.
Gringo123
I have a few questions that I would like to post on this site involving powers. First of all, can someone please tell me how to write the small figures that represent powers? I can do it on Microsofy packages, but not on this site.
2x = 2[*SUP]x[*/SUP] without the * (the X2 button)
or [*tex)2^x[*/tex] without the * (check the Σ button)
When in advanced options for a reply or when starting a thread if you want 'to the power of' where it has the X^2 where the 2 is above the x click that and insert your value which is being put to the power of in the middle of the code i.e. x2 is just x[.SUP]2[/SUP] just for example i put a fullstop in the first SUP.
I prefer the tex option, myself. Makes it easier to write other complicated math stuff.
[tex](\frac{x}{2})^2 = \frac{x^2}{4}[/tex]
Tex is very flexible and powerful. For example parenthesis, brackets and curly braces can be scaled with
\bigr \bigl \Bigr \Bigl \biggr \biggl \Biggr and \Biggl
[tex]\bigl({{x}\over{2}}\bigr)^2 = \frac{x^2}{4}[/tex]
[tex]\biggl({{x}\over{2}}\biggr)^2 = \frac{x^2}{4}[/tex]
[tex]\Bigl({{x}\over{2}}\Bigr)^2 = \frac{x^2}{4}[/tex]
[tex]\Biggl({{x}\over{2}}\Biggr)^2 = \frac{x^2}{4}[/tex]
x[.SUP]2[/sup]
If you see what looks like some fancy LaTeX work, such as the things in elect_eng's post, if you double-click the expression, you can see the script that he used that renders that way.
[tex]x^2 should give me x to the power of 2. here goes![/tex]
and x^2
You're missing the tex tags! [t ex] x^2 [/t ex] (remove the spaces between the t and e)
You need both opening and closing tag:
[tеx]x^2[/tеx] -> [tex]x^2[/tex]
  • · Replies 25 ·
