Degeneracy and Symmetrization Requirement
  • Context: Graduate
  • Thread starter Thread starter hbweb500
    Degeneracy
The discussion revolves around the concept of degeneracy in two-particle systems, specifically focusing on fermions in an infinite square well. Participants explore the implications of symmetrization requirements and the nature of energy eigenstates in this context.
  • One participant presents a wavefunction for two noninteracting fermions and questions why the states appear to have the same energy but are not considered degenerate.
  • Another participant suggests that the two states presented are actually the same due to differing only by a negative sign, implying they are linearly dependent.
  • A later reply confirms that if two eigenvectors differ only by a scale factor, they are not distinct eigenvectors, thus not degenerate.
  • Another participant introduces the idea of phase factors, noting that multiple states can be constructed from the original states, but these do not represent new states due to the overall phase being irrelevant.
  • One participant questions the exclusion of spin degrees of freedom when discussing fermions, suggesting that the antisymmetry could also involve spin components.
  • A later reply clarifies that the example is drawn from a textbook, indicating the context of the discussion.
Participants generally agree that the states in question are not distinct due to linear dependence, but there is a disagreement regarding the treatment of spin in the context of fermionic wavefunctions.
Some participants note the potential for confusion regarding the treatment of states and the implications of symmetrization, as well as the relevance of spin in defining fermionic states.
hbweb500
I am encountering two-particle systems for the first time, and I am a little confused about something.
Consider a infinite square well with two noninteracting particles, both fermions (though, disregard spin degrees of freedom, this is a strictly 1-d scenario).
So I go to write down the states of the system corresponding to different energies. Consider the case:
[tex]\psi_{23} = \frac{1}{\sqrt{2}} \left[ \psi_2(x_1) \psi_3(x_2) - \psi_3(x_1) \psi_2(x_2) \right][/tex]
Where
[tex]\psi_n (x) = \sqrt{\frac{2}{a}} \sin n \pi x / a[/tex]
This corresponds to energy
[tex]E = \frac{13 \hbar^2 \pi^2}{2 m a^2}[/tex]
This is all good. What I don't get is this: why isn't this energy degenerate? In other words, isn't the state:
[tex]\psi_{32} = \frac{1}{\sqrt{2}} \left[ \psi_3(x_1) \psi_2(x_2) - \psi_2(x_1) \psi_3(x_2) \right][/tex]
Also an energy eigenfunction of the Hamiltonian, with the same eigenvalue. Aren't the two states distinct?
Now, the symmetrization requirement says:
[tex]\psi(x1,x2) = -\psi(x2,x1)[/tex]
for fermions, which is the case above. I feel like this is relevant. But I still see there being two separate states with the same energy. Isn't this the definition of degeneracy?
It does get very confusing with the sums and differences and symmetrizations etc, but I wonder if you haven't made the very simple mistake of writing out two states which are the same as each other except for a negative sign? So they're actually the same state.
Ah, its as simple as that. If two eigenvectors are the same up to a scale factor, they are the same eigenvector. I was forgetting that.
Thanks.
The two states you wrote down are linearly dependent. They only differ up to an overall minus sign.
[tex]\psi_{23} = -\psi_{32}[/tex]
Two states are considered degenerate when they are not linearly dependent.
You can in fact construct an infinite number of states which are all eigenstates of the Hamiltonian. Namely,
[tex]\psi = e^{i\theta}\psi_{32}[/tex]
where [itex]0\leq \theta< 2\pi[/itex]. All these states are eigenstates, with the values [itex]\theta=0[/itex] and [itex]\theta=\pi[/itex] corresponding to your two functions. But you do not consider these states as "new states", since the overall phase doesn't matter.
EDIT: too slow..
That was helpful too, I hadn't thought about the phase factor. Thanks!
I don't understand what you have written. How can you have fermions without considering spin? Are you just saying that you are only going to accept spatial wavefunctions that satisfy the anti-symmetry property of fermionic wavefunctions? That is fine I guess, but the issue with that is there is another class of solutions where the spatial part of the wavefunction is symmetric under exchange, but the antisymmetry is provided by the spin portion of the wavefunction.
All of this is usually worked out in some detail in a standard textbook ... it can often be found under the heading of "Pauli Exclusion Principle" in the context of excited states of the helium atom.
I understand, this is just an example I am pulling from Griffiths.
  • · Replies 0 ·
