Thread Closed
Help calculating torque of servo for gripper to hold part.
Share Thread Thread Tools
Feb16-10, 05:27 PM   #1
I have this problem. I'm trying to calculate the minimal servo torque for the gripper to hold the part in place.
Mass of load is 170grams. u friction between load and walls is 0.5.
the diameter of wheel on which the pegs that pull the grippers is 2cm.
2. Relevant equations
Force to squeeze * Friction between load and gripper walls > Mass of cube
Torque=Force * radius
3. The attempt at a solution
F(friction)=0.17kg x 0.5=0.085N
F(G)=0.17kg x G = 1.666N
F=F(f) + F(g)= 1.751N
T=1.751N*0.01m=0.01751Nm
This is probably wrong...
Any ideas?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb16-10, 06:15 PM   #2
nvn
Recognitions:
Homework Helper Homework Help
Quote by duzO View Post
F(f) = (0.17 kg)*0.5 = 0.085 N
duzO: This is not the correct formula for friction force. What is the general formula for friction force? Keep trying. Your formula for weight, F(g), is correct. Don't you want the summation of vertical forces on the gripped object to equal zero? Keep developing your formulas. You are getting close.
Feb16-10, 07:15 PM   #3
Quote by nvn View Post
so itll be F=umg . friction force=friction x normal force
so you are saying that mg=umg+F ?
1.66=0.833+F;
F=0.827N ?
Feb16-10, 08:44 PM   #4
nvn
Recognitions:
W acts downward. 2*Fs acts upward. Perform a summation of vertical forces, and set it equal to zero.
|Fs| ≤ mus*N
Very good. Now what is N? Write an expression for N. N comes from the servo, right? Try again.
Feb16-10, 09:39 PM   #5
mg + 2(umN) = 0 ?
N=Torque/radius?
so Torque=gR/2u = 0.098Nm?
Feb16-10, 10:08 PM   #6
nvn
Recognitions:
m*g should be negative, not positive. Fs = mu*N, not u*m*N. N = T/diameter, not T/radius. m = mass, mu = static coefficient of friction, N = normal force, Fs = frictional force. Try again.
Thread Closed
Thread Tools
Similar Threads for: Help calculating torque of servo for gripper to hold part.
Thread Forum Replies
Robotic gripper circuiot problems Electrical Engineering 1
calculating the net torque! help! Introductory Physics Homework 8
Using a vacuum system to hold a part... Materials & Chemical Engineering 8
[SOLVED] Torque Part 2 Introductory Physics Homework 1
