Thread Closed
Gamma spectrum Na-22: Peak origins
Share Thread Thread Tools
Feb17-10, 04:21 AM   #1
Hey,
For my first post here, I had a question about the gamma spectrum of Na-22.
I measured the gamma spectrum of Na-22 with a Ge-spectrometer. Using Genie-2000 software I saw two peaks in the spectrum, 1274 keV (peaksurface 3981±1,74%) and 511 keV (peaksurface 25494±0,68%). (Horizontal axis is divided into channels, each representing an energy band. The vertical axis represents the number of counts)
As an assignment, I have to explain the origins of these peaks and why there is so much difference in peaksurface.
The peak at 511 keV is electron-positron annihilation, I guess. And if I interpret this source* correctly, the peak at 1274 keV is the result of both electron capture (which the assignment wants me to ignore) and beta+ decay?
Another question I had was why the peak at 511 keV is so much higher (a lot more surface)? It is true that electron-positron annihilation yields two photons, but they travel in opposite directions so, in generl, the chance the Ge-spectrometer measures both is quite small. (The sample lies on top of the spectrometer)
Thanks in advance for the help.
*=http://community.middlebury.edu/~PHManual/gamma.html
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Feb17-10, 10:18 AM   #2
Look at this plot of attenuation coefficients for photons in germanium:
http://physics.nist.gov/PhysRefData/...emTab/z32.html
Make sure you are measuring peak areas and not just the counts in the highest channel. In particular look at these attenuation coefficients in germanium.
0.50 MeV 8.212E-02 cm2 per gram
1.25 MeV 5.101E-02 cm2 per gram
Bob S
Feb18-10, 05:20 AM   #3
I hadn't considered this effect before, thanks for bringing it to my attention. I think I can finish my assignment with this.
Thanks again!
Thread Closed
Thread Tools
Similar Threads for: Gamma spectrum Na-22: Peak origins
Thread Forum Replies
Gamma ray Energy Spectrum of Cd-109 and Sn-113 Nuclear Engineering 6
peak copper (and peak other metals)? Earth 12
the party's over: peak oil has distracted us from peak helium! General Discussion 11
Mass spectrum-need 3 peak designations Biology, Chemistry & Other Homework 1
Dirac Gamma matrices including gamma^5, and the Spacetime Metric g_uv General Physics 8
