| Thread Closed |
Air in Tire Question |
Share Thread | Thread Tools |
| Aug3-04, 03:23 AM | #1 |
Suppose you have the air inside a tire travelling down the length of the tire (that is, in circular motion inside the tire). Now as the air slows down inside the tire, what happens to the tire pressure?
| Aug3-04, 04:53 AM | #2 |
Why would the air be circulating in the first place? But if it were, and it slowed down...then the pressure would increase. This is because traveling air has lower pressure, which is called the venturi effect (sp?).
| Aug3-04, 01:30 PM | #3 |
I wonder if the effect would be measurable. It is my understanding that certain vehicles have equipment to report air pressure in the tires to a gauge in the dashboard. If the car is brought to a stop, the air inside the tires should continue to circulate in the direction tire was spinning. But this continued motion should gradually slow down over time. I wonder if a person with an air pressure gauge in the dashboard can watch the air pressure in the tire drop rather suddenly as they bring the car to a stop, and then gradually rise as the air inside the tire slows to a stop, applying more lateral pressure against the gauge.
| Aug3-04, 02:44 PM | #4 |
as the air moves faster the pressure increases this is because the air molecules bounce of the tyre walls more frequently generating more heat
| Aug3-04, 02:52 PM | #5 |
Recognitions:
| Aug3-04, 04:27 PM | #6 |
The tire is resting flat on the ground. It does not matter how the air was made to move initially. Yes, I think Bernoulli effects are important. The deformation of the tire is not an issue.
So far we have one saying the pressure increases, and another that says the pressure decreases. |
| Aug3-04, 04:41 PM | #7 |
hello jondubya
try this simple experiment check the tyres pressures on your car, then take your car for a drive. recheck your tyre pressures noting that the temperature or the tyre has increased,you can feel this with your hand. let it cool down again and recheck. If you have seen top fuel drag cars there rear tyres are virtually flat until they wheel spin and heat up (which increases the pressure). when they cool down they diflate again. P.S I used to be responsible for keeping the fastest street legal bettle in the world in a straight line and this is one of the considerations i had too account for I hope this helps |
| Aug3-04, 05:50 PM | #8 |
Hmmm, would the centripedal force exerted on the air particles by the tire increase pressure?
| Aug3-04, 05:57 PM | #9 |
yes, but this would make the particles move faster thus heat them up.
also this does not only apply to round objects. any movement would have this effect. think of a microwave oven. put a raw egg in it and laugh when it explodes then think about what caused this? increase in heat which increases pressure. |
| Aug4-04, 07:04 PM | #10 |
There are several factors involved in this situation...so its hard to tell now. You have bernouli affects, centripital acceleration, friction against the ground. Lets think about this, the car is moving, since air has very little friction, it takes a long time for it to start circulating. When it circulates, you have the air pressure drop from bernouli affects. The centripital force makes the air molecules pile up on the bottom of the tire, therefore, having a higher pressure. The friction of the tire against the ground heats up the rubber, but i think we can rule this one out because rubber is a bad thermal conductor. But there is another source of friction, which is the friction of the air against the bottom and sides of the tire (more against the botton since thats the area of higher pressure). SO, now we have higher pressure and temperature at the bottom of the tire, while a little lower pressure towars the center, but at the same time we have all this air circulating, which causes the overall pressure to go down (this is alll while the car is in motion). So, when the car slows down and stops, the air takes a little while to stop circulating (which makes it increase in pressure) because of the small amount of friction it has. At the same time you have the air (hot in the biginning) cooling down slowly, which causes a decrease in pressure. From my understanding of it, there is an equilibrium effect going on here. I dont think you can qualitatively conclude whether it will increase or decrease in pressure.
| Aug5-04, 02:52 PM | #11 |
| Aug5-04, 02:54 PM | #12 |
| Aug5-04, 03:04 PM | #13 |
Recognitions:
If Bernouli effects are important, then the cross section of the tire may well be an issue. Even relatively sane looking fluid dynamics situations can lead to problems where there are sponaeous jumps in pressure. It's a deep and difficult field that I don't know much about.
That said, I believe that the pressure on the exterior wall woud decrease, and the pressure on the interior wall would increase. Since the value is typically on the inside of the tire, that would indicate that the 'tire pressure' would increase while the air stops. However, if you're measuring the pressure by checking the tire diameter, you might find that it decreases. |
| Aug7-04, 06:15 PM | #14 |
Assume a very large cross-section.
This should be easy to verify. Every tire shop has a tire balancer. Simply spin the tire on the balancer until the air inside is reliably moving with the tire. Stop the tire and measure the temperature. Then wait a few hours and measure the temperature again. Good physics experiment. :) |
| Aug8-04, 03:38 AM | #15 |
JohnDubYa, did u even read everything in the post i had? In that post i was using the tire on a moving car.
| Aug8-04, 12:33 PM | #16 |
Yes, but *I* originated the post. Having the tire spinning on a tire balance is not going to heat the tire by any significant factor, which was my objection to your placing the tire on a moving car. You specifically mentioned "friction on the ground," which complicates the issue for no good reason.
| Aug18-04, 09:03 PM | #17 |
Why would the air go round with the tire? It would seem that a gas will have random disorder to it. There is nothing pertruding out of the tire, ie. vanes to cause the flow to stirr as it goes round. Only the particles that are along the sides of the wall would be carried around. It would seem that as the tire moves forward, more of the air would strike the back of the tire as it moves forward in time, so the back of the tire would heat up the most. If this were to continue for a long period, the pressure would drop, as a result of tranfering energy to the rear inner tire wall. After a while, I would think the pressure in the tire should go back up as heat is put back into the air that gave it up to friction.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Air in Tire Question
| Changed my first tire!!!! | General Discussion | 51 | ||
| Tire | Introductory Physics Homework | 3 | ||
| The world according to the tire guy | General Discussion | 29 | ||
| tire pressure question | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Bike Tire | Mechanical Engineering | 1 | ||
