Is there a Proof for the Rational Integral of x/(a^2+x^2)?
The discussion centers around the integral of the function x/(a²+x²) and whether there is a proof for its antiderivative, specifically whether it equals (1/2)ln|a²+x²| + c. Participants explore various methods of integration and verification of the result.
  • Homework-related
  • One participant, mazzo, seeks a proof for the integral of x/(a²+x²).
  • Another participant suggests differentiating the proposed antiderivative to verify its correctness.
  • A different participant, mike, attempts a substitution method but expresses uncertainty about its validity.
  • Another reply confirms that mike's final step is correct but questions the logical progression leading to it.
  • One participant proposes an alternative substitution (u = a² + x²) that simplifies the integral to a more straightforward form.
Participants do not reach a consensus on the best method for solving the integral, and there are differing opinions on the logical steps involved in arriving at the antiderivative.
Some participants express uncertainty about the validity of their substitutions and the logical connections between steps, indicating potential gaps in the reasoning process.
mazzo
Dear Forum,
I've been trying to find a proof for the following:
[tex] <br /> \int \frac{x}{a^2+x^2}dx = \frac{1}{2}\ln|a^2+x^2|+c<br /> [/tex]
After many hours I've resorted to asking for help - any ideas anyone?
cheers,
mazzo
If you just want to check this, you can simply differentiate the right hand side and show that you get the integrand back.
If you want to calculate it (forgetting about the result for the time being), then you may notice that x is the derivative of 1/2(a2 + x2) and try a variable substitution u = a2 + x2.
thanks for this. But I found that when I substituted in this value for u it doesn't work. I tried
[tex] x^2 = t [/tex]
[tex] 2xdx = dt[/tex]
[tex] xdx = dt/2[/tex]
then
[tex] \int \frac{x}{a^2+x^2}dx = \frac{1}{2} \int \frac{dt}{(a^2+t)} = \frac{1}{2}\ln|a^2+x^2|+c[/tex]
can I do the last step, is this correct ?
cheers,
mike
It is correct, if you differentiate the result you can check that your anti-derivative works. But I don't see how it logically follows, other than "educated guessing."
If you take my substitution (u = a2 + x2) your integral reduces to the elementary
[tex]\int \frac{du}{u} = \log|u|[/tex]
for which no guesswork is required.
