How Do You Calculate Forces and Motion for Loaded and Unloaded Lorries?
The discussion focuses on calculating forces and motion for both unloaded and loaded lorries, specifically using the mass of 2700 kg for the unloaded lorry and an additional load of 800 kg. The unloaded lorry accelerates to 30 mph (approximately 13.41 m/s) in 10 seconds, resulting in an acceleration of 3 m/s² and a force of 8100 N required for acceleration. The total distance traveled during the initial acceleration and constant velocity phase is calculated to be 375 m. The discussion also addresses the need to convert units and apply relevant equations such as F = ma and S = (u + v)/2 * t.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of kinematic equations for motion
  • Ability to convert units from mph to m/s
  • Familiarity with momentum calculations
  • Learn how to convert units between mph and m/s accurately
  • Study kinematic equations in detail, focusing on displacement and velocity
  • Explore momentum change calculations in mechanical systems
  • Practice sketching velocity-time graphs for different motion scenarios
Mechanical engineering students, physics enthusiasts, and anyone involved in vehicle dynamics or motion analysis will benefit from this discussion.
enrmmell
Mechanical systems - Please help me with this question! :(
Person_Number M (kg) D (m) R (m/s2)
<431383> 2700 60 1.4
Mechanical Systems Engineering
Assignment 1
An unloaded lorry of mass M kg accelerates from rest and reaches a velocity of 30mph in 10 seconds. It then travels at constant velocity for half a minute before the driver applies the brakes and brings the vehicle to rest over a distance of D m.
The lorry is then loaded with 800 kg of building materials that need to be transported over a total distance of 0.6 km. After loading, the lorry accelerates over a distance of 80m to attain a velocity of 30mph again. The vehicle subsequently maintains constant velocity before decelerating to rest at a rate of R m/s2.
Using only your own personal input data as given on the assignment 1 “input values” spreadsheet (penalties will result from not using your OWN data):-
a) Find for the unloaded lorry: ( 6 marks)
i) the force required to accelerate the vehicle, and the retarding force necessary to bring it to rest;
ii) the total time and the total distance traveled during this period.
b) Find for the loaded lorry : ( 7 marks)
i) the force required to accelerate the vehicle and the retarding force necessary to bring it
to rest;
ii) the total time taken during this period and the distance traveled at constant velocity.
c) Calculate the % change in the momentum of the lorry from loaded to unloaded, whilst traveling at the specified constant velocities. ( 3 marks)
d) Draw the ‘velocity-time’ graph of the motion of the lorry in its unloaded and loaded states, indicating clearly salient points and values. ( 4 marks) Relevant equations:
S=(u+v/2)t S = Displacement V = velocity A= acceleration
F= ma
Any help on this question would be extremely grateful as its just a little assignment i need to do - i don't have a clue how too :S I also have to sketch a VxT graph but i will be able to handle that haha :P any help would be grateful cheers guys
Regards mark
The Work i have done so far is
a = (v-u/t) = 30 - 0 /10 = 3ms^2
F = mxa = 2700 x 3 = 8100 N
8100 is the force required to accelerate?
Retarding force : m(-a) = 2700 x (-3) = -8100N ??
Total time.. = 50 seconds? distance traveld 15x50/2 = 375m ??
Am i correct or have i got it totally wrong?
Welcome to PF!
Hi enrmmell ! Welcome to PF! :smile:
erm :redface: … you need to convert 30mph into m/s :wink:
12K
  • · Replies 17 ·
  • · Replies 20 ·
