How can you apply the rule f(-x)=-f(x) when solving equations?
  • Context: High School
  • Thread starter Thread starter trip7
The discussion revolves around the application of the properties of even and odd functions, specifically the rule f(-x) = -f(x). Participants explore how to determine whether a function is even, odd, or neither through examples and clarifications related to curve tracing and symmetry.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants express confusion about how to "use" the property f(-x) = -f(x) in practice, particularly in the context of identifying even and odd functions.
  • One participant clarifies that f(x) = f(-x) is the property of even functions, while f(-x) = -f(x) is the property of odd functions, emphasizing the need to evaluate and compare expressions to draw conclusions.
  • Examples are provided, such as f(x) = x^3, demonstrating that it is an odd function since f(-x) = -f(x).
  • Another example, g(x) = x^2, is discussed to illustrate that it is an even function because g(-x) = g(x).
  • A participant questions whether multiplying all terms by -1 is a correct approach to applying the rule, seeking clarification on the technique.
  • There is a reiteration of the importance of evaluating f(-x) and comparing it to f(x) to determine the function's properties, with a warning against oversimplifying the process.
Participants generally agree on the definitions of even and odd functions, but there is some disagreement regarding the clarity of the application of these concepts, particularly in the context of curve tracing and symmetry. The discussion remains somewhat unresolved as participants express varying levels of understanding.
Some participants struggle with terminology and the correct process for evaluating functions, indicating a need for clearer guidance on the steps involved in determining whether a function is even, odd, or neither.
trip7
How do you use f(-x)=-f(x)?
I understand how to use f(x)=f(-x)
Ex:
y=x^3
=(-x)^3
=(-x)(-x)(-x)
=-x^3
but I am confused with the previous.
Any help and examples would be appreciated!
trip7
Mathematics news on Phys.org
what on Earth do you mean by "use"?
What are you talking about??
What do you mean by "using"?
The example used is wrong for all other choices than x=0.
f(x)=f(-x) is the property of an even function (defined on some interval -a<=x<=a, a>0).
f(-x)=-f(x) is the property of an odd function (defined on some interval -a<=x<=a, a>0).
Usually, exercises involving even/odd require us to determine whether a given function is either even or odd (or neither or both).
Let us take the case f(x)=x^3, and we assume it is defined on the whole number line.
We will investigate whether f is even or odd:
By the definition of f(x), we have:
f(-x)=(-x)^3 (just plugging in -x at x's place in the expression for the function)
We now manipulate the right-hand side:
(-x)^3=(-1)^3*x^3=-x^3
But, x^3=f(x), and we therefore have:
f(-x)=-f(x)
That is, f(x)=x^3 is is seen to be an odd function
f(-x) = -f(x) = (-1)*f(x)
Pardon my lack of proper terminology. I am trying to find even, odd, neither, or both. What I meant by 'using' is arildno's example "just plugging in -x at x's place in the expression for the function." I am trying to learn curve tracing and checking for symmetry I replaced x with -x aka f(x)=f(-x). I forgot how to find the origin and for some reason f(-x)=-f(x) comes to mind. Is there a simple technique like replace x with -x? Hope this isn't more confusing than previous post.
trip7
According to Gonzolo's equation, it appears that you just multiply all terms by -1. Is that correct? I really appreciate everyone help!
trip7
trip7
"Im trying to learn curve tracing and checking for symmetry I replaced x with -x aka f(x)=f(-x)."
This is COMPLETELY, TOTALLY WRONG!
Read what I wrote carefully:
First, I EVALUATE f(-x)
Then, I COMPARE the gained expression with what I know of f(x)
Then I can draw a CONCLUSION if f is either odd, even or neither or both.
Another example:
Let g(x)=x^2
Then, we EVALUATE: g(-x)=(-x)^2=(-1)^2*x^2=x^2
But, COMPARING with g(x), I see that I can CONCLUDE:
g(-x)=x^2=g(x), that is, g(-x)=g(x)
That is, g is an even function.
Yet another example:
Let h(x)=x^2-x
Then:
h(-x)=(-x)^2-(-x)=x^2+x
But, the expression x^2+x is not equal to h(x), nor is it equal to -h(x)!
That is:
h(x) is neither even or odd!
Thanks for the extra examples arildno, I get it. I put way more into it than I should have!
  • · Replies 22 ·
  • · Replies 23 ·
