Stored Energy In a Capacitor
  • Thread starter Thread starter yankeekd25
    Capacitor Energy
The problem involves a parallel plate capacitor connected to a battery, initially filled with a dielectric material. The stored energy is given, and the scenario changes when the dielectric is removed and the distance between the plates is altered. The objective is to determine the new stored energy in the capacitor.
  • Participants discuss the need to find the voltage of the battery and the new capacitance after changes to the capacitor's configuration. Questions arise about whether the charge remains constant and how that affects voltage and stored energy.
There is an ongoing exploration of the relationships between capacitance, charge, voltage, and stored energy. Some participants suggest that the voltage remains constant while the capacitance changes, leading to further questions about how these changes impact the stored energy. Guidance has been offered regarding the proportional changes in capacitance and energy.
Participants note that not all necessary information is available to calculate specific values, and there is a focus on understanding the relationships between the variables rather than deriving final answers.
yankeekd25
A parallel plate is connected to one battery and has a material with a dielectric constant of 1.57 filling the space between the plates. The stored energy for the parallel plate capacitor is 21.6 Joules. While connected to the same battery the distance between the plates is decreased by a multiple of 2.3 and the dielectric is removed so that there is nothing between the plates. What is the stored energy in the capacitor now in Joules?
C= K Enot A / d
Co= C/ K
U = 1/2 QV, or Q^2 / 2c
I'm not really sure where to go on this problem. Do I have to somehow find the voltage of the battery and do something with that? Or maybe the C or Q? thanks.
Yes, you need to find the voltage of the battery first. Then you need to find the new capacitance.
Using the U= 1/2 Q V formula? Or something else? If that formula, how do I find Q?
When the dielectric is removed and the plates are moved closer together does Q change or does it remain the same?
Would Q change?. is there something you can do with the equations then to find an equation for V?
You do not have to find the actual voltage or capacitance - in any case you do not have all the information required for this.
What IS required is the proportion by which capacitance is changed.
Te remainder of this post was in error due to misreading of the original question, and so has been deleted.
Please think again. The battery remains connected. If C changes and if Q remains constant (according to you) what happens to V?
V will increase?
I can only apologise for not having read the initial post carefully enough - I had assumed that the capacitor was initially charged, then isolated from the battery.
If the battery remains connected then the problem is simpler, as the voltage must remain constant and only the capacitance changes .
The charge (CV) and the stored energy (CV2/2) will each change in the same proportion as the capacitance, so you need to find that proportion, and multiply it by the initial energy.
  • · Replies 17 ·
  • · Replies 28 ·
