Object going up inclined plane with friction, how far does it go?
The problem involves a box sliding up a 15-degree inclined plane with a coefficient of kinetic friction of 0.180 and an initial speed of 1.50 m/s. To determine how far the box travels before coming to rest, one must account for the forces acting on the box, including gravitational force and friction. The solution requires applying kinematic equations and trigonometric principles to incorporate the incline's angle. The final distance calculated is 0.265 meters.
  • Understanding of Newton's laws of motion
  • Knowledge of kinematic equations
  • Familiarity with trigonometry, specifically sine and cosine functions
  • Concept of friction and its coefficient
  • Study the derivation of kinematic equations for inclined planes
  • Learn how to calculate net forces on an object on an incline
  • Explore the effects of different coefficients of friction on motion
  • Practice problems involving inclined planes with varying angles and speeds
Students studying physics, particularly those focusing on mechanics and motion on inclined planes, as well as educators looking for practical examples of friction and kinematics in action.
travisped
A box is sliding up an incline that makes an angle of 15 degrees with respect to the horizontal. The coefficient of kinetic friction between the box and the surface of the incline is .180. The initial speed of the box at the bottom of the incline is 1.50 m/s. How far does the box travel along the incline before coming to rest?
the book this problem came from referred to an example where they were on a flat surface and they used x=(v2-vo2)/2(-.18*9.8). I have no idea how to incorporate the 15 degree incline into my answer, the solution in the book says .265m if that helps.
Make a diagram of all the forces acting on the object, then consider which are slowing it down in it's ascent up the ramp. You'll need to use trig.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 19 ·
