Could a very large telescope see a star as a disk?
  • Context: Stargazing
  • Thread starter Thread starter Thecla
    Disk Star Telescope
The discussion revolves around the capability of very large telescopes to resolve stars as disks rather than points of light. Participants explore the necessary telescope size and conditions under which a close star like Sirius could be seen as a disk, considering factors such as angular resolution, atmospheric interference, and optical techniques.
  • Some participants suggest that a telescope with a diameter of 4 meters could resolve a nearby star like Betelgeuse as a disk, while Sirius remains unresolved due to its distance.
  • Others argue that atmospheric conditions significantly limit the resolution of ground-based telescopes, making it difficult to see stars as disks without advanced techniques.
  • Several methods for improving resolution are proposed, including adaptive optics, interferometry, and lucky imaging, though the effectiveness of these methods varies.
  • One participant emphasizes that even with a space-based telescope and perfect optics, the calculation of necessary telescope size is complex and may not yield straightforward answers.
  • There is mention of the impact of computer image processing techniques on observational astronomy, allowing for improved resolution beyond traditional limits.
  • Some participants reflect on the historical context of astronomical techniques and the evolution of technology in the field.
Participants express differing views on the feasibility of resolving stars as disks, with some asserting that it is possible under certain conditions while others maintain that significant challenges remain. The discussion does not reach a consensus on the necessary telescope size or the effectiveness of various techniques.
Limitations include the dependence on atmospheric conditions for ground-based telescopes, the complexity of calculations involved in determining telescope size, and the unresolved nature of the discussion regarding the capabilities of different telescopes.
Thecla
Hi
When I was a kid, the largest telescope was Mt Palomar, a little over 5 meter diameter mirror. In spite of its large size, I always read that stars appeared as points of light through the scope if it were used visually, i.e. stars are too small and too distant to appear as disks.
However with the advent of very large telescopes(10 to 15 meters diameter)and the possibility of 40 meter telescopes in the future, I have a question:
How large a telescope is necessary to show a close star like Sirius as a small disk, approximately equal to the size of the planet Neptune as seen through a 4" telescope at medium power?
For calculation purposes assume this is a space-based telescope so there are no atmospheric interferences and also assume perfect optics
Astronomy news on Phys.org
It would need very large angular resolution. In other words, tag.
A nearby big star like Betelguse would be a disk for a 4m telescope.
The problem is the atmosphere
There are three options
1, Adaptive optics = big complex and expensive
2, Interferometer, either a number of telescopes linked together or a few tricks you can do with patches of a single telescope
3, Lucky imaging - you take lots of very short exposure images and add the 'good' ones
Thecla said:
Hi
I'm very very lazy right now, but I'm willing to bet you could calculate this on your own.
Sirius is only 10 LY distant and pretty big. It's disc is resolvable with existing scopes, if desired. Betelguese is not resolvable as a disc, it is at least 500 light years distant.
It ain't much to look at, but Betelgeuse is resolvable...and Sirius is not:
Explanation: Betelgeuse (sounds a lot like "beetle juice"), a red supergiant star about 600 lightyears distant, is shown here in this Hubble Space Telescope image which represents the first direct picture of the surface of a star other than the Sun.
http://zuserver2.star.ucl.ac.uk/~idh/apod/ap960122.html
Sirius is twice the diameter of the sun - Betelgeuse is 1000x the diameter of the sun.
The problem is that they aren't points of light but blurry disks. There are a few in resolving stars. The first problem is diffraction. If you put light through a pinhole is spreads out. This also happens with telescopes and so the image of a star is blurred by the light in the telescope spreading out.
The other problem is the atmosphere. Basically if you have an image of a star, the atmosphere is going to blur it out.
We can go through this calculation, but I think it's the wrong problem. Anything larger than about 10 inches is going to be limited by the atmosphere blurring. The smallest thing that you can see with any ground telescope without image processing is 1 arcsecond.
Also what people have been able to do is to take images from two telescopes that are far apart and electronically combine then so that they create an image from one giant "artificial" telescope. This technique has been used in radio astronomy for a long time, but people are starting to use it in optical astronomy.
http://www.universetoday.com/2010/01/12/unprecedented-images-show-betelgeuse-has-sunspots
One other thing, is that a lot of the recent advances in astronomy have been because of cheap computers and electronics. One thing about space telescopes is that it turns out to be not that useful for getting precision pictures of things since it turns out that you can do more with ground telescopes and lots of computers. The thing that Hubble *does* get you is that you can take measurements in frequencies that get blocked on the ground (ultraviolet).
It's nowhere close to that bad. With computer image processing techniques and good seeing, amateurs (such as myself) can get somewhere around .2 arcsec.
Here's an article on achievable resolution and the Cassini Division in Saturn's rings, which has a width of about .75 arcsec and is resolvable even in even relatively small telescopes. http://www.cloudynights.com/item.php?item_id=1132
The one arcsecond number is for raw unprocessed images. With computer image processing you can get things much, much better, and something that is great about these image processing techniques is that they are very widely available (i.e. you can download the software from the web). One thing that is amazing is how cheap computer power has totally transformed observational astronomy. When I was a young graduate student, people were just starting to experiment with these techniques.
I had an interesting talk with someone that was not much older than me, and I got one of those "when I was a young graduate student, you kids are spoiled" talks in which he was talking about what people did when they used photographic plates. You had to carefully and slowly develop the photograph plates, and there was none of the fancy, smancy computer processing. When you wanted to measure something you had to get a ruler and record the number on a notepad.
I had to do that as an undergrad, and you had to cut the glass plates in the dark and then lick them to taste which side had the emulsion before loading them in the telescope.
Damn - I only just turned (officially) middle aged and already I sound like the old guy.
  • · Replies 34 ·
15K
  • · Replies 21 ·
  • · Replies 39 ·
