Solid Mechanics: Cantilever Beams & Loads on Neutral Axis
In a cantilever beam subjected to a load at the free end, the normal stresses at a point on the neutral axis are indeed zero due to the absence of bending and axial stresses at that specific location. When constructing a Mohr circle for this point, the center of the circle is positioned at the origin, confirming that only shear stresses are present at the neutral axis. This conclusion is contingent upon the load being applied perpendicular to the beam axis.
  • Understanding of cantilever beam mechanics
  • Knowledge of normal and shear stress concepts
  • Familiarity with Mohr's circle for stress analysis
  • Basic principles of static equilibrium in structural engineering
  • Study the mechanics of cantilever beams under various loading conditions
  • Learn about the derivation and application of Mohr's circle in stress analysis
  • Explore the effects of axial loads on bending stress in beams
  • Investigate the relationship between shear and normal stresses in structural elements
Structural engineers, civil engineering students, and professionals involved in the analysis and design of beam structures will benefit from this discussion.
milan666
Hi,
In a cantilever beam with a load on the free end, at a point on the neutral axis, will the normal stresses (due to bending stress and axial stress) be zero? Or am i wrong? And if i was to draw a Mohr circle for that point at the neutral axis, would the center of the circle be the origin? I am assuming that because there are only shear stresses at that point.
Thanks
Agreed, as long as the long is perpendicular to the beam axis.
12K
