Thread Closed
Young's Modulus - estimate elastic limit
Share Thread
Feb20-10, 03:44 PM   #1
I'm completing a homework for Young's Modulus and one question asks to estimate the elastic limit for the wire which was used.
I can see where this approximately is on the graph I have drawn. When the question asks to estimate the elastic limit, does this mean to simply state the mass which was applied when the elastic limit was reached?
Thanks
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb20-10, 05:17 PM   #2
I had another think about it. Would I be right in thinking the elastic limit would be the mass where this happens (in kg) multiplied by gravitational acceleration and the result of this multiplication stated in Newtons?
Feb20-10, 08:16 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
No, the elastic limit is the stress at yield (yield stress of the wire, in N/m^2, or Pascals), not the force at yield. What are you plotting on your graph?
Feb20-10, 08:45 PM   #4
Thanks PhanthomJay, it's mass / grams on the y-axis and extension / mm on the x-axis.
Feb20-10, 10:24 PM   #5
Recognitions:
Quote by ZedCar View Post
Looks then like your plotting mass (presumably a mass hanging down on the wire, yielding a weight/force unit) versus extension.. You want to find the stress at yield. What is it? Are the properties of the wire given?
Feb21-10, 12:21 PM   #6
Quote by PhanthomJay View Post
Yes, that's right.
Ah, I see what you mean! I need to find the stress at the yield point.
So I'll obtain the applied force by using the mass (in kg) at which the elastic limit is reached and multiply this by 9.81 (acceleration due to gravity). Then divide this number by the cross sectional area of the wire. Ensuring when calculating the cross sectional area of the wire the diameter is in the SI unit of the metre.
So the final figure for the estimation of the elastic limit would be in the units of N/m2
Feb21-10, 02:27 PM   #7
Recognitions:
Yes, that's right.
Yes, excellent. And i'm sure you know that a N/m^2 is called a 'pascal' for short.
Feb21-10, 02:42 PM   #8
Yes, thanks very much!
Thread Closed
Similar discussions for: Young's Modulus - estimate elastic limit
Thread Forum Replies
Young's Modulus Materials & Chemical Engineering 4
young's modulus and bulk modulus of cooked pasta Classical Physics 4
young's modulus Introductory Physics Homework 5
Young's modulus Introductory Physics Homework 3
