Proving No Equivalence of Norms in l_1
  • Thread starter Thread starter BSCowboy
    Equivalent
The problem involves demonstrating that the norms ||·||₁, ||·||₂, and ||·||ₓ in the space l₁ are not equivalent. The original poster attempts to show that the ratios of these norms approach infinity or zero for certain sequences.
  • Exploratory, Assumption checking
  • Participants discuss the need for a sequence of sequences rather than a single sequence to prove the non-equivalence of the norms. They explore examples and question the convergence of proposed sequences.
Some participants have provided guidance on how to construct sequences that meet the criteria for the norms in question. There is an ongoing exploration of the implications of the norms diverging as n approaches infinity.
There is a focus on ensuring that sequences are within the l₁ space, with discussions about absolute convergence and the definitions of the norms involved.
BSCowboy
In [tex]l_1[/tex] (each element is a sequence of numbers such that the series converges absolutely) show that no pair of the norms [tex]||\cdot||_1, \, ||\cdot||_2, \, ||\cdot||_{\infty}[/tex] are equivalent norms.
[tex]||x||_1=\sum_{i=1}^{\infty}|x_i|[/tex]
[tex]||x||_2=\left(\sum_{i=1}^{\infty}|x_i|^2\right)^{\frac{1}{2}}[/tex]
[tex]||x||_{\infty}=\mbox{ max}\{|x_i|:i=1,2,\ldots\}[/tex]
I realize I need to show:
[tex]\dfrac{||x||_1}{||x||_2}=\infty \text{ or } 0\quad \dfrac{||x||_1}{||x||_{\infty}}=\infty \text{ or } 0\quad \dfrac{||x||_2}{||x||_{\infty}}=\infty \text{ or } 0[/tex]
but I am having problems finding such a sequence and showing this is true.
You can't find a SINGLE sequence that will prove they aren't equivalent. You need to find a sequence of sequences. For example, can you find a sequence of sequences x_n where ||x_n||_infinity remains constant as n increases but ||x_n||_1 goes to infinity? That would prove ||_infinity and ||_1 were not equivalent norms, right?
How about [tex]x_n=n^{-1/2}[/tex]
Then: [tex]||x_n||_1[/tex] diverges while [tex]||x_n||_{\infty}=1[/tex]
But, this sequence does not converge absolutely so it wouldn't be in the space, right?
That's still a single sequence. You want a sequence of sequences. Define x_n to be the sequence where the first n terms are 1 and the rest are zero. What are ||x_n||_infinity and ||x_n||_1?
In that case,
[tex]||x_n||_1=\infty[/tex]
and
But again, this is not a convergent sequence, so it wouldn't be in the space in the first place right?
BSCowboy said:
In that case,
and
You aren't quite getting this. x_n isn't a single sequence. It's a different sequence for each value of n. x_1=(1,0,0,0...), x_2=(1,1,0,0,0..), x_3=(1,1,1,0,0...) etc etc. All of those are in l_1. And, yes, ||x_n||_infinity=1. But ||x_n||_1=n, right? What does that tell you about the possibility of the norms being equivalent?
You're right, I was being dense (my steady state as of late).
So,
[tex]\dfrac{||x_n||_1}{||x_n||_{\infty}}=n[/tex]
Then,
[tex]\dfrac{||x_n||_1}{||x_n||_2}=\dfrac{n}{\sqrt{n}}=\sqrt{n}[/tex]
Lastly,
[tex]\dfrac{||x_n||_2}{||x_n||_{\infty}}=\sqrt{n}[/tex]
Or, am I still lost?
No, I think you are getting it. Since all of those diverge as n->infinity, that means you can't bound any of your norms by a constant times the other norm, right?
Right, Thanks Dick. I appreciate it. I guess I kept getting stuck because I wasn't thinking about a sequence of sequences correctly and I kept thinking of [tex]l_1[/tex] incorrectly.
