Hydrogen spin-orbit interaction
The discussion revolves around the spin-orbit interaction in hydrogen, specifically focusing on the energy level splitting due to this interaction. Participants explore the implications of quantum numbers, angular momentum, and the coupling of spin and orbital angular momentum in the context of fine structure levels.
  • Some participants discuss the energy separation formula for spin-orbit interaction, noting that the total angular momentum j is a vector sum of l and s, leading to different possible values for j.
  • There is confusion regarding the use of positive values for spin (s=1/2) in calculations, with participants questioning why only positive values are considered when coupling l and s to yield j.
  • One participant clarifies that angular momentum is always positive, and different couplings of l and s yield different values for j, which can range from |l-s| to l+s.
  • Another participant introduces the Law of cosines in the context of spin-orbit interaction, explaining that the angles between the vectors change depending on the coupling, which affects the energy calculations.
  • Historical context is provided regarding the classical origins of the spin-orbit interaction equation, referencing Thomas and Pauli's contributions to the understanding of this phenomenon.
Participants generally agree on the positive nature of l and s, but there remains uncertainty and confusion regarding the implications of using these values in the context of spin-orbit coupling and the resulting energy levels. The discussion does not reach a consensus on the interpretation of these values in calculations.
Participants express uncertainty about the assumptions underlying the use of positive values for spin and the implications for energy calculations. The discussion highlights the complexity of angular momentum coupling and the need for clarity in the application of quantum mechanical principles.
ian2012
For a particular energy level in hydrogen, with quantum numbers n and l, one will find when considering the spin-orbit interaction, the level is split into two fine structure levels with energy separation:
[tex]\Delta E_{s.o.}=\beta_{nl}(l+1/2)[/tex]
I was trying to prove this result. The spin of an electron is 1/2. Therefore there are two possible values for the total angular momentum, as the spin can be either +-1/2. Therefore using (and the relevant energy spin-orbit equation):
[tex]\Delta E_{s.o.}=E_{j=l+1/2}-E_{j=l-1/2}[/tex]
gives the first result. However, when you follow the proof through I am confused because in the energy spin-orbit equation (not stated here) you use s=1/2 for both possible energy states. However you use l=+-1/2 for the angular momentum. Why is this? Surely you'd use s=+-1/2 for the electron spin also?
Angular momentum is always positive. However, the total angular momentum j is a vector sum of l and s, so it may assume values spanning from |l-s| to l+s, when both l and s are non-zero. So, it is not that you use positive and negative values for angular momentum in the equation, it is that you need to consider all the ways that l and s can couple to yield j. Clear?
Yeah, i understand why l is positive. However, my question was concerning the spin. When you prove the result you use only the positive value for spin (s=1/2), for both the j=1+1/2 and j=l-1/2 states.
[tex]E_{s.o.}=\frac{\beta}{2} [j(j+1)-l(l+1)-s(s+1)][/tex]
You use positive values for l and s in the above equation. I don't understand why the positive values for s, since as you said, you have to consider all the ways l and s can couple to yield j.
right ... and for different couplings you have different values of j. If you assume we are talking about the 2p orbital, then l=1, s=1/2, and we have two possibilities:
2P3/2 state: l=1, s=1/2, j=l+s=3/2 --> E=beta/2(15/4 - 8/4 - 3/4) = beta/2
2P1/2 state: l=1, s=1/2, j=|l-s|=1/2 --> E=beta/2(3/4 - 8/4 - 3/4) = -beta
Okay, so strictly l and s are always positive. It is just for different coupling, j will take different values: |l-s|< or = j < or = l+s ?
You got it. :wink:
The spin-orbital interaction (L S coupling) is gotten using the Law of cosines as follows, (though the sign is a little different),
[tex]2 \hat{L} \cdot \hat{S} = (\hat{L}+\hat{S})^2(=\hat{J}^2) - \hat{L}^2 - \hat{S}^2 = (J(J+1) -l(l+1)-s(s+1)) \hbar^2[/tex]
Here we have to consider the precession of the orbital and spin movement, so we use [tex]J(J+1),l(l+1),s(s+1)[/tex] instead of [tex]J^2, l^2, s^2[/tex].
The s is positive, but the figures of the triangle are different between J=L-1/2 and J=L+1/2.
The three sides of both triangles are [tex]\sqrt{J(J+1)}, \sqrt{l(l+1)}, \sqrt{s(s+1)}[/tex]. (Here, only J is different.)
This means the angles between [tex]\sqrt{l(l+1)}[/tex] and [tex]\sqrt{s(s+1)}[/tex]are different in both cases.
Strange to say, the equation of the spin-orbital interaction is gotten by the "classical" methods.
Thomas used the classical rotation and classical relativity to get this equation. (This value coincided with the Sommerfeld's equation.)
So Pauli said in the Novel lecture, as follows,
Although at first I strongly doubted the correctness of this idea because of its classical-mechanical character, I was finally converted to it by Thomas' calculations on the magnitude of doublet splitting.
On the other hand, my earlier doubts as well as the cautious expression <<classically non-describable two-valuedness>> experienced a certain verification during later development...
  • · Replies 18 ·
