Unraveling the Mystery of Integration: Area Under the Curve
The discussion revolves around understanding the concept of integration, specifically how it relates to finding the area under the curve of the function y = x². Participants explore the mathematical reasoning behind the antiderivative and its geometric interpretation, as well as the implications of multiplying the original function by a factor related to its exponent.
  • One participant expresses confusion about how multiplying the original function by (x/n) leads to the area under the curve, particularly for the function y = x².
  • Another participant suggests that the relationship between the area of the rectangle and the area under the curve is an observation rather than a geometric proof.
  • A participant points out that the area of the rectangle is not the total area under the curve but rather the area from 0 to x.
  • One participant describes the relationship as a coincidence, comparing it to other mathematical identities that are true but lack a straightforward explanation.
  • Another participant recommends watching videos on Riemann sums to better understand the concept of area under the curve.
Participants do not reach a consensus on the geometric interpretation of integration or the reasoning behind the multiplication by (x/n). There are multiple competing views regarding the nature of the relationship between the function and the area under the curve.
Some participants acknowledge the complexity of the topic and the potential for confusion when transitioning from basic to advanced concepts in calculus.
BBRadiation
I am having trouble figuring out how an integration works.
Consider the function, y = x2 . The antiderivative is x3 / 3 or in other words its x2 (x/3). How come multiplying the original function by (x / n) (where n represents the exponent + 1) will lead to the area under the curve.
Put in another way, let's define the above in terms of a graph. Consider the function y = x2 and you want to find the area from 0,1.
All you are doing to find the area is x2 (x/3) . You are creating a rectangle in which the dimensions are x2 by (x/3). If the function we were dealing with were x3, the rectangle that would yield the area under the curve would be x3 by ( x / 4)
http://img237.imageshack.us/img237/6906/image1sj.png
How come the above rectangle just happened to be the total area under the curve? How did this work out and why does it work out?
In order to try and figure this out, I searched the history of calculus and found this from wiki, but I didn't really understand it:
In this paper, Newton determined the area under a curve by first calculating a momentary rate of change and then extrapolating the total area. He began by reasoning about an indefinitely small triangle whose area is a function of x and y. He then reasoned that the infinitesimal increase in the abscissa will create a new formula where x = x + o (importantly, o is the letter, not the digit 0). He then recalculated the area with the aid of the binomial theorem, removed all quantities containing the letter o and re-formed an algebraic expression for the area. Significantly, Newton would then “blot out” the quantities containing o because terms “multiplied by it will be nothing in respect to the rest”.
If you read any standard calculus book, you'll see how formulas for areas under such curves are derived, and why they are true.
The equality of the areas of the region you have in mind and the area of that rectangle happen to be a "fun fact", I don't think there's a way to show this geometrically, it's just something that we can observe from the formula we get for the area under the curve x^n.
Also, the area of the rectangle is not the total area under the curve, it's area under the from 0 to x.
Do you have any specific books in mind?
Sorry, that's what I meant.
I am just having trouble understanding why multiplying the original function by (x/n) can lead to the area under the curve.
It's a coincidence. Kinda like how sum of the first n odd numbers is n^2 or how
[tex] 1^3 + 2^3 + 3^3 + ... = (1 + 2 + 3 + ...)^2[/tex]
We can prove these formulas are true, but the fact that they are true are very neat coincidences.
http://www.sci.uidaho.edu/polya/math170/modules/?mod=14&sec=1&sub=0
Watch the Reimann sums video @ this link. It's short and will convey to you the general idea of what is going on.
This video is then extremely worth watching afterwards, (actually any videos by this guy is worth watching!),
http://www.5min.com/Video/Areas-Riemann-Sums-and-Definite-Integrals-169053988
Then, if you'd then like to know more, keep watching the videos and there's also some great videos @ www.khanacademy.org to go a little deeper and get a good textbook on the subject. Btw, don't bother with wikipedia it's terrible for beginning to understand a lot (but not all) of math stuff and will scare you away because of the way it jumps from simple to mind bogglingly difficult to simple on about every math topic...
  • · Replies 24 ·
  • · Replies 20 ·
