| Thread Closed |
How do I find the Moment of Inertia? |
Share Thread | Thread Tools |
| Feb23-10, 12:46 AM | #1 |
In this experiment a physical pendulum consisting of a rod and two large rubber stoppers (on top of each other) is swung from a point 1 mm from the end point. Calculate the moment of inertia of the pendulum about the point of suspension? Data: m=mass of rod=97.1 g M=mass of the stoppers and the bolt=200 g L=1 meter=length of rod d=distance between the center of mass (CM) of the rod and the point of suspension=499 mm D=distance between the center of mass of the stoppers and the Point of suspension=879 mm R=distance between the Center of Mass of the rod-stopper system and the point of suspension=689 mm theta (max)=the max angular displacement of the system from equilibrium (i.e. the max angular amplitude). Remember, theta (max) should be less than about pi/12 radian for the motion to be simple harmonic)=90 degrees T(sub e)=the experimental period of oscillation of the pendulum. (measure and record at least three sets of 10 complete oscillations)=17.39 seconds/10 oscillations. r=the distance from the center of the ruler to the point of rotation (.499 m) 2. Relevant equations Note: I was sick when my teacher taught this so I learned the following from a friend. use parallel axis theorem+MOI of point masses (I)totalrod = (I)ruler + (I)mass (I)mass= MR^2 where R = the distance from the center of the point mass to the rotation and M is the mass for the point mass (200 g) (I)ruler is the parralel axis theorem which is like (I)ruler= (I)centerofmass + Md^2 where (I)center of mass is equal to 1/3Mr^2 where r is the distance from the center of the ruler to the point of rotation (.5 meters) + Md^2... 3. The attempt at a solution I was sick...I dunno Sorry! Help..eh :) Thanks so much! This is due tomorrow so Urgency is somewhat required LOL...I wish I was smart |
| Feb23-10, 01:48 AM | #2 |
Recognitions:
Well you know that Ipoint mass=mr2, so you can find the I for the masses about the point of suspension (POS).
For a rod, about its center, the moment of inertia is 1/12ML2. Now the parallel axis theorem states that IPOS=IC+mRPOS2 You should be able to get the I for the rod about the POS now. Now that both of the 'I's are about the same axis, the total I about that axis, is just the sum of the individual 'I' values. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How do I find the Moment of Inertia?
| How do you find the moment of inertia of a polygon? | General Math | 4 | ||
| how do I find the moment of inertia for a curve? | Introductory Physics Homework | 8 | ||
| I need to to find the moment of inertia for the system | Introductory Physics Homework | 1 | ||
| find the moment of inertia | Precalculus Mathematics Homework | 5 | ||
| Find Moment of Inertia and Frictional Torque | Introductory Physics Homework | 10 | ||
