Electric field strenth question
The discussion centers on calculating the required electric field strength for a crossed-field velocity selector with a magnetic field of 1.0 x 10^-2 T, allowing 10.0 keV electrons to pass through undeflected. The relevant equations involve the relationship between electric and magnetic forces, specifically F = qE for electric force and F = qvB for magnetic force. The participants emphasize the need to derive the electron's velocity from its kinetic energy to accurately determine the electric field strength.
  • Understanding of electric and magnetic forces
  • Familiarity with kinetic energy calculations
  • Knowledge of the relationship between voltage and electron energy
  • Proficiency in using the Lorentz force equation
  • Learn how to calculate electron velocity from kinetic energy (10.0 keV)
  • Study the Lorentz force equation in detail
  • Explore the principles of crossed-field velocity selectors
  • Investigate the relationship between electric field strength and potential difference
Physics students, electrical engineers, and professionals working with particle accelerators or electromagnetic devices will benefit from this discussion.
dev-hud
A Crossed-field velocity selector has a magnetic field of magnitude 1.0 x 10^-2T. What electirc field strenght is required if 10.0 keV electrtons are to pass through undeflected?
ef - 1.0 x 10^-2
I know it gives magnetic field, except how and what formula do we use to figure out the electric field strenght when we are also given 10.0 keV?
ef - 1.0 x 10^-2
You should write down the relevant equations for the magnetic forces and the electric forces. You'll find that your answer of "ef - 1.0 x 10^-2" isn't quite right. Some of the relevant equations are a function of velocity.
"10.0 keV" is a measure of energy; kinetic energy in this case, to be specific. Do you know of any unknown variables in your magnetic or electric field/force equations that you might be able to determine if you happened to know the kinetic energy of the electrons?
  • · Replies 25 ·
  • · Replies 23 ·
