Find the area of the region shared by the curves
  • Thread starter Thread starter apiwowar
    Area Curves
The area of the region shared by the curves r=6cos(θ) and r=6sin(θ) can be calculated using polar coordinates. The curves represent circles with a radius of 3, centered on the x-axis and y-axis, respectively. To find the overlapping area, one effective method is to integrate along the sine curve from θ=0 to θ=π/4 and then double the result, exploiting the symmetry of the curves. Alternatively, one can compute two separate integrals: one along the sine curve from θ=0 to θ=π/4 and another along the cosine curve from θ=π/4 to θ=π/2.
  • Understanding of polar coordinates and their representation
  • Knowledge of integration techniques in calculus
  • Familiarity with the properties of trigonometric functions
  • Ability to sketch and analyze curves in a Cartesian plane
  • Learn how to compute areas in polar coordinates using integration
  • Study the properties of symmetry in mathematical functions
  • Explore advanced integration techniques, including double integrals
  • Practice sketching polar curves and identifying their intersections
Students and educators in mathematics, particularly those studying calculus and polar coordinates, as well as anyone interested in geometric interpretations of trigonometric functions.
apiwowar
find the area of the region shared by the curves r=6cosx and r=6sinx
i know that if you graph those two functions you get two circles, both with radius 3, the first one has its center on the cartesian x-axis and the other has its center on the y axis.
i also know that if you draw a line through the center of where they meet the angle of that line is pi/4
what i don't know is which function to integrate and what would be the lower limit of integration.
i know that the formula is 1/2 integral from a to b of (g(x)^2 - f(x)^2)
making 6sinx the second function makes sense since that's the bottom part of the area that i want to find but you can't make the first function 6cosx and integrate from 0 to pi/4 because that would give you more than just where the two functions overlap
any help or ideas about how to solve this would be appreciated.
The formula that you "know" is incorrect. A ray going out from the origin should extend to only one or the other of the two circles, so you won't have g(x)^2 - f(x)^2 in your integral. If you have drawn a sketch of the region you will see this.
An easy way to do this is to exploit the symmetry of the two curves, and integrate along the circle r = 6sint from t = 0 to t = pi/4, then double that value. Note that I changed the x you had to t (for theta), since the curves are (I believe) curves in polar coordinates, in which r and theta appear, but x and y don't.
Another way is one that doesn't exploit symmetry. To do it this way you need two integrals, one in which you integrate along the sine curve from t = 0 to pi/4, and the other in which you integrate along the cosine curve back to the origin, as t runs from pi/4 to pi/2.
Both techniques should give you the same area.
yea i used x instead of theta
but i completely see that now. i just wasnt thinking straight.
thanks
  • · Replies 19 ·
