Resistance and temp co-efficient?
  • Thread starter Thread starter neduet
    Resistance
The resistance of a conductor with a cross-section of 10 cm² and a specific resistance of 7.5 ohm cm at 0°C is calculated to be 90,000 ohm/km at 40°C. This calculation incorporates the temperature coefficient of the material, which is 0.005 per degree Celsius. The formula used is R = ρL/A, where ρ is the resistivity, L is the length, and A is the cross-sectional area. The increase in resistance is attributed to the temperature rise, resulting in a 9,000 ohm increase from its original resistance at 0°C.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the concept of resistivity and its units (ohm cm)
  • Knowledge of temperature coefficients and their impact on resistance
  • Basic algebra for manipulating equations
  • Study the effects of temperature on electrical resistance in conductors
  • Learn about different materials and their specific resistances
  • Explore advanced topics in thermoelectric effects and their applications
  • Investigate how to measure and calculate resistance in practical circuits
Electrical engineers, physics students, and anyone involved in materials science or electrical circuit design will benefit from this discussion.
neduet
A conductor has cross-section of 10 cm2 and specific resistance of 7.5 ohm cm at 0 degree C
what will be its resistance in ohm per/kilometer when the temperature is 40 degree C ?
take temperature co-efficient of the material is 0.005 / degree C
i can't find the solution of it. please give me solution if you can
please help me
Resistance of a wire in Ω
R = ρL/A
ρ is resistivity of the material in Ω-cm
L is length in cm
A is cross-sectional area in cm²
R = (7.5 Ω-cm)(L) / 10 cm²
R/L = 0.75 Ω/cmR/L = 0.75 Ω/cm x 100000 cm/km = 75000 Ω/km
R/L = 75000 Ω/km x [1+ (0.005/C)*40C]
R/L = 90000 Ω/km
Therefore, the resistance of the conductor at 40°C would be 90,000 Ω/km. This calculation takes into account the temperature coefficient of the material, which indicates how much the resistance changes with temperature. In this case, the resistance increases by 0.5% per degree Celsius. So at 40°C, the resistance would be 9,000 Ω higher than at 0°C.
10K
  • · Replies 96 ·
14K
