What is the power dissipated in the 5 ohm resistor in this complex circuit?
The power dissipated in the 5 ohm resistor of the described circuit can be calculated by first determining the total effective resistance. The circuit consists of a 12 volt battery, a 4 ohm resistor in series with a parallel combination of a 2 ohm and 1 ohm resistor, and another series combination of a 5 ohm and 1 ohm resistor. By applying Kirchhoff's Current Law and simplifying the circuit, the total current can be found, which is then used to calculate the power dissipated in the 5 ohm resistor using the formula P = I²R.
  • Understanding of series and parallel resistor combinations
  • Familiarity with Kirchhoff's Current Law
  • Knowledge of Ohm's Law
  • Ability to calculate power using the formula P = I²R
  • Learn how to simplify complex resistor networks
  • Study Kirchhoff's Voltage Law for circuit analysis
  • Explore the concept of effective resistance in circuits
  • Practice calculating power in various resistor configurations
Electrical engineering students, circuit designers, and anyone interested in analyzing and solving complex resistor circuits.
daiviko
ok there is a picture that goes along with it, i will try and draw it in as best i can.
We've got a 12 volt battery. a 4 ohm resistor is in series with this big thing I am going to describe next. A two ohm and 1 ohm resistor that are in series are in parallel with a 5 ohm and 1 ohm resistor that are also in series. What is the power dissipated in the 5 ohm resistor?
____2ohm__1ohm___
l--4ohm--l____5ohm__1ohm__l
l l
l l
—————12v---------------------
i doubt that will come out okay but w/e
dang it..
You need to find the currents and voltages of the circuit. Just keep simplifying the circuit by combining series and parallel resistances into effective resistances. Once you find the total effective resistance seen by the load, you can find the total current. This current, by Kirchoff's Current Law, must be split up between the parallel branches that you have. So you then need to know the voltage drop across the branches to find the currents in the individual branches. Once you have the current in the 5 Ohm branch, you can find the power.
  • · Replies 16 ·
