Combinatorial Problem: Does Sum = Binomial Coefficient?
  • Context: Graduate
  • Thread starter Thread starter mathstime
The discussion revolves around a combinatorial problem involving the equality of a summation of binomial coefficients and a single binomial coefficient. Participants explore the conditions under which the equality holds, considering different ranges for the summation and proposing various methods of proof, including induction.
  • One participant proposes that the sum \(\sum_{i=0}^n \binom{n-1+d-i}{d-i}\) may equal \(\binom{n+d}{d}\), but another suggests the sum should actually range from 0 to d.
  • Another participant rewrites the left-hand side (LHS) as \(\sum_{i=0}^d \binom{n-1+d-i}{n-1}\) and the right-hand side (RHS) as \(\binom{n+d}{n}\), suggesting a combinatorial interpretation.
  • One participant expresses confusion and requests clarification on the reasoning presented.
  • A later post introduces a modified problem, stating the goal to show that \(\sum_{k=0}^d \binom{n+d-k}{n} = \binom{n+d}{n}\) and proposes using induction for proof.
  • Another participant claims that the LHS of the modified problem is not equal to the previously discussed LHS, emphasizing the need for careful consideration of the binomial coefficient properties.
  • Further elaboration is provided on how to interpret the counting of subsets related to the maximum element, suggesting a combinatorial approach to understanding the equality.
Participants generally agree on the need to clarify the limits of the summation and the properties of binomial coefficients. However, multiple competing views remain regarding the correct formulation of the problem and the methods of proof, leading to an unresolved discussion.
There are limitations in the assumptions regarding the ranges of summation and the interpretations of the binomial coefficients, which have not been fully resolved. The discussion also reflects varying levels of understanding among participants regarding the combinatorial arguments presented.
mathstime
Does [tex]\sum_{i=0}^n \binom{n-1+d-i}{d-i} = \binom{n+d}{d}??[/tex]
I'm going to go ahead and assume that the sum on the LHS goes from 0 to d, not from 0 to n. In this case, yes. Because [tex]\binom {a}{b} = \binom{a}{a-b}[/tex], you can rewrite the LHS as
[tex]\sum_{i=0}^d \binom{n-1+d-i}{n -1}[/tex]
For the same reason, you can rewrite the RHS as [tex]\binom{n+d}{n}[/tex].
Consider this hint: [tex]\binom{n-1+d-i}{n -1}[/tex] counts the number of subets of {1, 2, 3, ..., n+d-i-1} that are have size n -1. How many subsets of {1, 2, 3, ..., n+d} of size n have maximal maximal element n+d-i?
I'm sorry I don't understand? Could you explain again?
Thank you for your help
Yes, you are correct. The summation should be from 0 to d.
I have actually altered the problem slightly. I want to show that
[tex]\sum_{k=0}^d \binom{n+d-k}{n} = \binom{n+d}{n}??[/tex]
I could maybe do this by induction on d as follows:
[tex] d=0 : \binom{n}{n} = \binom{n+1}{n+1}[/tex]
assume true for all d
[tex] \sum_{k=0}^{d+1} \binom{n+(d+1)-k}{n} = \binom{n+d+1}{n} + \sum_{k=1}^{d+1} \binom{n+d+1-k}{n}[/tex]
[tex] = \binom{n+d+1}{n} + \sum_{k=0}^{d} \binom{n+d-k}{n} [/tex]
and this is where I get stuck? ...any ideas?
I get that this equals
[tex] \binom{n+d+1}{n} + \binom{n+d+1}{n+1} = \binom{n+d+2}{n+1}[/tex]
is this correct?
If so, how can I show that this equals [tex]\binom{n+d}{n}[/tex] ??
anyone??
This is not correct. The LHS you have here is not equal to the LHS you had before.
More details on my response:
You should know that if a and b are any two non-negative integers, [tex]\binom{a}{b} = \binom{a}{a - b}[/tex]. e.g., if I have 5 apples, the number of ways I can choose 2 apples is the same as the number of ways I can choose 3 apples. This is easy to see: to every choice of 2 apples, corresponds a choice of 3 apples (the apples that I didn't choose).
This said, this means that we have:
[tex]\sum_{i=0}^d \binom{n-1+d-i}{d-i} = \sum_{i=0}^d \binom{n-1+d-i}{(n-1 + d - i) - (d-i)} = \sum_{i=0}^d \binom{n-1+d-i}{n-1}[/tex]
Also,
[tex]\binom{n+d}{d} = \binom{n+d}{(n+d) - d} = \binom{n+d}{n}[/tex]
So in fact, we are trying to prove that:
[tex]\sum_{i=0}^d \binom{n-1+d-i}{n-1} = \binom{n+d}{n}[/tex]
Let's see how we can prove this. Let's first examine the RHS. What is this number? It's the number of ways we can choose n things from a set of n + d objects.
Let's now look at the LHS. What does this count? Well, consider the set {1, 2, ..., n, n+1, ..., n +d}. As observed above, the RHS counts the number of size n subsets of this set.
Aside from computing [itex]\binom{n+d}{n}[/itex], there's another way we can count these. Here's the idea: for each of n, n+1, n+2, ... , n+d, count the number of subsets of size n whose maximum element is that number, then add up the results.
For example, if n = 3, d = 2, the number of subsets of size n with maximum element n, is 1, i.e. only the set {1,2,3}. The number of subsets with maximum element of size n+1 (4) is 3, i.e. {1,2,4}, {2, 3, 4}, {1, 3, 4}. The number of elements of subsets of size n with maximum element n + 2 = 5 is 6 (I won't list them). 1 + 3 + 6 = 10. You can easily check that [itex]\binom{3+2}{3} = 10[/itex], as expected.
Now do you see where this is going? Can you show that \binom{n-1+d-i}{n -1} counts the number of size n subsets of {1, 2, ..., n+d} whose maximum element is n + d - i?
  • · Replies 19 ·
  • · Replies 17 ·
