Help solving a Cauchy-Euler Equation (Differential equation help)
  • Thread starter Thread starter Jim4592
The discussion focuses on solving a Cauchy-Euler equation represented by the differential equation x²y'' + xy' + 4y = 0. The solution involves finding the roots of the characteristic equation r² + 4 = 0, resulting in complex roots r = 2i and r = -2i. To express the solution without imaginary numbers, the general solution is transformed using Euler's formula into the form y = c₁e^{0}cos(2ln(x)) + c₂e^{0}sin(2ln(x)), where the coefficients are derived from the roots of the characteristic equation.
  • Understanding of Cauchy-Euler equations
  • Familiarity with differential equations and their solutions
  • Knowledge of Euler's formula and complex numbers
  • Ability to manipulate characteristic equations
  • Study the derivation of solutions for Cauchy-Euler equations
  • Learn about Euler's formula and its applications in differential equations
  • Explore the method of solving homogeneous linear differential equations with constant coefficients
  • Investigate the implications of complex roots in differential equations
Students and educators in mathematics, particularly those studying differential equations, as well as professionals seeking to deepen their understanding of Cauchy-Euler equations and their solutions.
Jim4592
x2y'' + xy' + 4y = 0
y = xr
y' = r xr-1
y'' = r(r-1)xr-2
x2[r(r-1)xr-2] + x [r xr-1] + 4xr = 0
(r2-r)xr + r xr + 4xr = 0
[(r2-r) + r + 4]xr = 0
r2 - r + r + 4 = 0
r2 + 4 = 0
from the quadratic equation i know that: r = 2i and r = -2i
so y = c1x2i + c2x-2i
my question is how can i remove the imaginary number from the answer.
Thanks in advanced!
x^2i can be expressed as e^(ln x^2i). Use Euler's equation to express that in terms of sine and cosine and you're done.
If the roots of your characteristic equation [itex]r^2 + (b-1)r + c = 0[/itex] (here a = 1, where a is the coefficient of r^2, b = 1, and c = 4) are complex (occurs since b^2 - 4ac < 0), then the general solution is
[tex]y= c_1 e^{\alpha x}\cos{\beta x} + c_2 e^{\alpha x}\sin{\beta x}[/tex]
where
[tex]r_1 = \overline{r_2} = \alpha + i\beta = \frac{-b}{2a} + i\frac{\sqrt{4ac - b^2}}{2a}[/tex]
so that
[tex]\alpha = \frac{-b}{2a} \mbox{ and } \beta = \frac{\sqrt{4ac - b^2}}{2a}[/tex]
(All you are doing is reducing Cauchy-Euler equation to a homogeneous linear differential equation with constant coefficients)
