Thread Closed
Need help looking up thermal properties
Share Thread Thread Tools
Feb27-10, 11:40 PM   #1
I'm trying to look up the specific enthalpy (h) at 4.8Mpa and 40 degrees celcius for water vapor/steam. It should be a saturated liquid.
3. The attempt at a solution
I know the specific enthalpy should be ~171.78KJ/Kg but I can't for the life of me figure out how the text book example comes up with that.
The value of specific enthalpy for a saturated liquid at 40ºC is 167.54KJ/Kg, obviously not quite right.. Any assistance would be great, probably a quick easy answer of something I'm missing / don't know.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb28-10, 12:39 AM   #2
Recognitions:
Homework Helper Homework Help
If it was stated that it is a saturated liquid then your enthalpy would just be the hf value at 40C or 4.8 MPa.
If they did not state that it was a liquid, you might need to find the quality, x, and find the enthalpy using the equation h=hf+xhfg
Feb28-10, 02:08 AM   #3
Quote by rock.freak667 View Post
I guess a little more information may be needed.. This is part of a problem dealing with a simple rankine cycle, however the example also accounts for pump/turbine efficiencies and pressure/temperature drops along the lines. It gives the pressure directly out of the pump as 5Mpa and once the working fluid has reached the boiler (just before going in, this is point 3) it is now at the 4.8Mpa & 40ºC.
Because it just came out of the pump and has yet to go into the boiler I know for a fact that the fluid is still a saturated liquid. As well as that piece of information, if you enter the 4.8/40º into an online thermo table it will tell you the enthalpy is 171.78 and the quality is N/A. This is an example out of the book, the auther just failed to explain how they arrived at this number.
Online thermo calc for steam/water I found while trying to figure this out earlier.. 1bar=100kPa, so my pressure of interest is 48bar.
http://www.steamtablesonline.com/steam97web.aspx
Thanks for the quick reply!
Feb28-10, 12:34 PM   #4
Recognitions:
Oh you mean the point is outside of the curve if that is the case, then I think you need to use
dh=v dP
[tex]\int_3 ^4 dh = \int_3 ^4 vdP[/tex]
[tex]h_4 - h_3 = v_3 (P_4-P_3)[/tex]
where v3 is the specific volume at 3 (vf). Try that.
Feb28-10, 02:05 PM   #5
dh=v dP
I'm assuming you mean where state three is the values at saturation and 4 is what I'm looking for?
Substituting with that:
[tex]h_4 - 167.54 = .001008(4800-7.384)[/tex]
[tex]h_4=172.371KJ/Kg[/tex]
Still not quite the 171.77 they have, but its a lot closer then what I found. I'm curious how the online thermo calculator goes about doing it..
Feb28-10, 05:01 PM   #6
Recognitions:
I am not exactly sure how the calculators do it. That is how I learned to do the basic Rakine cycle. Point 4 was usually calculated using the formula I gave you. I do not know if the calculators use a different method or formula.
Thread Closed
Thread Tools
Similar Threads for: Need help looking up thermal properties
Thread Forum Replies
thermal properties of materials,please!!!!!! Introductory Physics Homework 0
Please help me with my THERMAL PROPERTIES OF MATTER... Introductory Physics Homework 1
Equivalent Thermal Properties of Egg General Physics 1
Thermal properties Introductory Physics Homework 11
Thermal Properties Introductory Physics Homework 11
