Thread Closed
Inversion of this Vandermonde matrix
Share Thread Thread Tools
Feb28-10, 08:09 AM   #1
I was trying to expand a three and more parameter functions similarly to the two-parameter case f(x,y)=(f(x,y)+f(y,x))/2+(f(x,y)-f(y,x))/2.
Anyway, to do the same for more parameters I need to solve
[tex]
\begin{pmatrix}
1 & 1 & 1 & \dotsb & 1\\
1 & \omega & \omega^2 & \dotsb & \omega^{n-1}\\
1 & \omega^2 & \omega^4 & \dotsb & \omega^{2(n-1)}\\
1 & \omega^3 & \omega^6 & \dotsb & \omega^{3(n-1)}\\
\vdots & &&& \vdots \\
1 & \omega^{n-1} & \omega^{2(n-1)} & \dotsb & \omega^{(n-1)(n-1)}
\end{pmatrix}\mathbf{x}=
\begin{pmatrix}
1 \\ 0 \\ 0 \\ 0 \\ \vdots \\ 0
\end{pmatrix}
[/tex]
with [itex]\omega=\exp(2\pi\mathrm{i}/n)[/itex]
Is there a closed form expression for x?
EDIT: Oh, silly me. I realized it's a discrete Fourier transform. So is this the correct way to expand then? In the 3 parameter case the solution would be
[tex]
f(x,y,z)=\frac13(f(x,y,z)+f(y,z,x)+f(z,x,y))+\frac13\left(f(x,y,z)+\ome ga f(y,z,x)+\omega^*f(z,x,y)\right)+\frac13\left(f(x,y,z)+\omega^*f(y,z,x) +\omega f(z,x,y)\right)[/tex]
with [itex]\omega=\exp(2\pi\mathrm{i}/3)[/itex]?
Now I'm just wondering why I get linear dependent terms when I consider the real part only?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb28-10, 09:17 PM   #2
Recognitions:
You're on the right track. It is convenient to write this equation in matrix notation as
[tex]Wx=b[/tex]
where b is the vector you wrote on the RHS. Since W is full-rank and non-singular, it is invertible and the solution to your problem is
[tex]x=W^{-1}b[/tex] .
You need the inverse of W, but this is easy since we know from the properties of the discrete Fourier transform (DFT) that the individual vector columns of W are independent. Each is an orthonormal basis vector of the DFT. In words, this follows because the component of signal at one frequency (cosine or sine at w_m) is independent to that at every other frequency w_n. In fact,
[tex]W^{-1} = W^{\dagger} [/tex]
that is, W is Hermitian (the dagger is the conjugate transpose operation) and unitary (you get the identity matrix in the next equation)
[tex]WW^{\dagger}=I [/tex] .
You can perform this multiplication explicitly it to see that this is so. Accordingly
[tex]x=W^{\dagger}b[/tex]
and you can write out the components of x explicitly.
Mar1-10, 06:00 AM   #3
I just wonder if that way to decompose a multiparameter function makes sense.
It's nicely symmetrical and generalizes to higher dimensions. However it introduces complex number where the initial function might actually be real only. And also I haven't included odd parity permutations of the function arguments...
Mar1-10, 09:50 AM   #4
Recognitions:
Sorry, I'm not following your comments. I provided the closed solution to Wx=b, where W is complex, which was the question asked in your first post. Are you looking for something else?
Mar1-10, 12:02 PM   #5
I did that exercise to find a way to extend the rule f(x,y)=(f(x,y)+f(y,x))/2+(f(x,y)-f(y,x))/2 to higher dimensions (I didn't explain the connection; just mentioned it in the intro). I assumed some cyclic symmetry for the final form of f(x,y,z)=... and with the help of the discrete Fourier transform (which I didnt recognise at first), I can find some "decomposition".
Now I wasn't sure if the decomposition is useful this way.
Thread Closed
Thread Tools
Similar Threads for: Inversion of this Vandermonde matrix
Thread Forum Replies
Vandermonde matrix Linear & Abstract Algebra 1
[SOLVED] Vandermonde Matrix - Help! Precalculus Mathematics Homework 2
finding determinant of Vandermonde matrix Linear & Abstract Algebra 2
Vandermonde matrix Calculus & Beyond Homework 0
Matrix Inversion Precalculus Mathematics Homework 3
