Determining the distribution function F(x): Statistics/Probability
The discussion revolves around determining the cumulative distribution function F(x) for a random variable X with a specified probability density function. Participants are exploring the integration of the density function and the continuity requirements of the cumulative distribution function.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the integration of the piecewise density function and its implications for continuity. Questions arise regarding the calculation of constants and the correct formulation of F(x) across different intervals.
Some participants have provided insights into the integration process and the necessity for continuity in the cumulative distribution function. There is an ongoing exploration of how values from previous intervals affect subsequent calculations, with no explicit consensus reached on the correct approach.
Participants are grappling with the implications of piecewise functions and the requirement that the cumulative distribution function must be continuous. There is mention of specific values and constants that need to be reconciled with the overall function behavior.
mikebro
For the random variable X with probability density function determine the distribution function F(x)
http://img20.imageshack.us/img20/3314/questiontsy.jpg
Cumulative Distribution Function
Integrate f(x) to get the distribution function:
F(X) =
  • 0, x ≤ -1
  • x[tex]^{2}[/tex]/2 + x, -1 < x ≤ 0
  • x - x[tex]^{2}[/tex]/2, 0 < x ≤ 1
  • 0, x > 1
The actual answer is
http://img297.imageshack.us/img297/426/answer.jpg
I understand that the equation must be integrated to get the distribution function, but where do the constants (1/2) come from and how are they calculated?
You can't just take a piecewise density function and find the indefinite integral of each piece separately. Notice your F(x) isn't continuous (any integrable density function must have a continuous cumulative distribution function), so it has to be incorrect.
Remember the cumulative distribution function is [itex]\int_{-\infty}^{x}f(t)\,dt,[/itex] where f is your density function (t is just a dummy variable). Now obviously the values of f for x less than or equal to 1 contributes nothing to the cumulative distribution function, so to find the values of F for [itex]-1<x\leq0,[/itex] you need to compute
[tex]\int_{-\infty}^{x}f(t)\,dt = \int_{-\infty}^{x} t + 1\,dt = \int_{-1}^{x} t + 1\,dt.[/tex]
Thanks, that helps clarify a bit. I solved the integral you posted and got the correct answer, but tried to solve the other 2 and got an answer different than what the professor gave.
To get the F for [itex]0<x\leq-1,[/itex] I used this integral:
[tex]\int_{-\infty}^{x}f(t)\,dt = \int_{-\infty}^{x} 1 - t\,dt = \int_{0}^{x} 1 - t\,dt.[/tex]
but since F(0) = 0, the answer I got isn't what the professor posted. Does the 1/2 carry over from the F for [itex]-1<x\leq0,[/itex] carry over to this one?
And for the [itex]x>1,[/itex] obviously the F is just 0 + Constant, is it just known that the value of this is 1 since it must add up to one?
mikebro said:
Does the 1/2 carry over from the F for [itex]-1<x\leq1,[/itex] carry over to this one?
Of course! I mean what you first calculated was the cumulative distribution function for x between -1 and 0, so F(0) = 1/2, not 0. I think you should try drawing the density out to get a geometric feel for the problem for now; this isn't hard once you do a few more of these.
For the last "piece" F(x) should just be 1, but remember you should be able to get this value by computing F(1). The cumulative density function should be continuous, and you should check this at the endpoints of each piece.
I actually do have a graph of the density function.
http://img64.imageshack.us/img64/8127/graphbo.png
But if F(0) = 1/2, when solving the integral above and doing F(x) - F(0), wouldn't that make it (x^2)/2 + x - (1/2)? What I meant was F(0) = 0 in context of the integral above, then adding the actual value of F(0) from the -1 < x ≤ 0 piece.
I am realizing these seem relatively easy as I work through it, but there's just a few small things I'm unsure of and can't find examples of in my textbook or lecture notes.
  • · Replies 20 ·
