What is the tension between two connected train cars in a toy locomotive system?
  • Thread starter Thread starter sheepcountme
    Locomotive Tension
The problem involves a toy locomotive system where a child pulls a locomotive with a specified force, and the task is to determine the acceleration of the train and the tension between the locomotive and the first car. The system includes friction and varying masses for the locomotive and the connected cars.
  • Participants discuss the application of Newton's laws and free body diagrams to analyze forces acting on the locomotive and the connected cars. There are attempts to derive equations for tension and acceleration, with some questioning the correctness of their equations and assumptions.
Participants are actively engaging with the problem, sharing their calculations and reasoning. Some have provided guidance on drawing free body diagrams and isolating forces, while others express confusion about the correct approach to finding tension. There is a mix of interpretations and methods being explored, with no explicit consensus reached.
Participants mention the importance of considering the correct mass for the free body diagram and the role of friction in their calculations. There is an acknowledgment of potential errors in calculations and the need for clarity on the forces involved.
sheepcountme
A child pulls on a toy locomotive of mass 0.979 kg with a force of 3.25 N to the right. The locomotive is connected to two train cars by cables. Friction in the axles results in an effective coefficient of kinetic friction between the floor and the train which is 0.110. One car has a mass of 0.952 kg and the other has a mass of 0.419 kg. (a) What is the acceleration of the train? (b) What is the tension in the cable between the locomotive and the car connected to the locomotive?
T-mg=ma
I found the acceleration just fine but I don't get how to find the tension between the two cars.
sheepcountme said:
T-mg=ma
Your relevant equation is not correct. How did you find the acceleration using that equation? Assuming you have determined the acceleration correctly, you must now draw a free body diagram of the engine alone. What forces act on the engine? What is the acceleration of the engine? Then solve for the cable tension force betweeen the engine and first car, using Newton's laws. Please also show your work for part a.
Well, I already had a free body diagram, with mg down, Fnormal up, 3.25N right and friction left.
For a, I found mg first for the whole train (23.03N), which would have to be the same as the normal force. So then using the given coefficient for friction and the normal force I found the friction force (23.03 x .110). Since the train is accelerating I subtracted this from applied force and set it equal to ma:
3.25-(23.03 x .110)=ma and plugging everything in solving for a I got .306m/s^2 for the acceleration.
I don't understand how I am just supposed to get the tension between the locomotive and the first car though.
You missed the tension in the cable in your free body diagram.
That looks good for part a. If you call the pulling force P, you used the equation P - friction = ma. Now are you at all familiar with free body diagrams? Draw a crude sketch of the entire train, then isolate the engine alone by drawing a circle around it. Enlarge that circled section in another sketch, and now look at the forces acting on it. You have P acting to the right. There are 2 more forces acting to the left, and 2 more forces acting vertically. What are they?
So it's the normal Force up vertically, mg down vertically, Push to the right, and friction+Tension to the left.
I just tried a few variations of P-(f+T)=ma but they didn't work out...am I on the right track? And should I be using the mass of the entire train or just the first engine?
You only use the mass of the system on which the law is applied. Here you draw f.b.d of the engine so use it's mass only.
I'm sorry, what are you referring to with f.b.d? Friction and something else?
If I use the mass of the one locomotive in the equation above P-(f+T)=ma for either all masses or the single mass I get the wrong answer so this equation can't be right..can you tell me where it's wrong?
f.b.d is free body diagram.
What value of friction are you using? Could you show your eqn.?
P-((mu * Fn) +T)=ma
sheepcountme said:
P-((mu * Fn) +T)=ma
Yes, but now you have to show us what value you are using for F_n.
For Fn I am using mg
Oh! Nevermind it works!
Lesson: never fully trust your calculator
  • · Replies 30 ·
18K
