Refrigeration - Fouling in the sizing evaporator and condenser
Fouling significantly impacts the performance of heat exchangers in refrigeration cycles, as outlined in the 2008 ASHRAE Handbook. It leads to increased resistance to airflow, reduced heat transfer coefficients, and higher fan power requirements. While sizing evaporators and condensers does not require direct consideration of fouling, awareness of its eventual impact on performance is crucial. Implementing filters can help mitigate fouling effects and maintain system efficiency.
  • Understanding of heat exchanger principles
  • Familiarity with the refrigeration cycle
  • Knowledge of ASHRAE standards and guidelines
  • Basic concepts of airflow and pressure drop in HVAC systems
  • Research methods for measuring fouling in heat exchangers
  • Learn about different types of filters for reducing fouling
  • Explore advanced heat exchanger design techniques to minimize fouling
  • Study the impact of fouling on energy efficiency in HVAC systems
HVAC engineers, refrigeration technicians, and system designers seeking to optimize heat exchanger performance and understand the implications of fouling in refrigeration systems.
alexisonsmith
Hey,
I am trying to determine the importantance and difference of fouling in sizing the evaporator and condenser in a Refrigeration cycle?
Thanks,
Alexisonsmith
I got this from the ASHREA Handbook:
Fouling, an accumulation of dust or condensates on heat exchanger
surfaces, reduces heat exchanger performance by increasing
resistance to airflow, interfering with mass transfer, and generally decreasing
heat transfer coefficients. Increased resistance to airflow increases
fan power requirements and may reduce airflow.
Increased pressure drop across the heat exchanger core can indicate
fouling and, with experience, may be used to establish cleaning
schedules. Reduced mass transfer performance (latent effectiveness)
indicates fouling of permeable membranes or desiccant sorption
sites. Heat exchanger surfaces must be kept clean to maximize
system performance.​
2008 ASHRAE Handbook - Heating, Ventilating, and Air-Conditioning Systems and Equipment (I-P Edition).
In terms of sizing the Evaporator and Condenser, fouling doesn't need to be taken into consideration, rather it is more important to know that it is there and will eventually cause degradation in performance.
To reduce fouling you can use a filter.
I hope that helps.
  • · Replies 18 ·
9K
  • · Replies 30 ·
