Power Requirements for VASIMR to Lift Objects on Earth
  • Thread starter Thread starter aquitaine
The VASIMR (Variable Specific Impulse Magnetoplasma Rocket) requires approximately 15 megawatts of power to lift a 1-ton spacecraft off the Earth's surface, significantly exceeding the 200 kW version currently under development for space applications. This calculation is based on a thrust requirement of 10,000 Newtons and a specific impulse of 3000 seconds, resulting in an exhaust velocity of 30 km/s. The high specific impulse of VASIMR leads to a low thrust-to-power ratio, necessitating substantial power for terrestrial launches.
  • Understanding of VASIMR technology and its operational principles
  • Knowledge of thrust and specific impulse calculations
  • Familiarity with Newton's laws of motion
  • Basic principles of rocket propulsion systems
  • Research advanced propulsion systems, focusing on VASIMR technology
  • Study the calculations involved in thrust-to-power ratios
  • Explore the implications of specific impulse on spacecraft design
  • Investigate current developments in high-power energy sources for propulsion
Aerospace engineers, propulsion system designers, and researchers interested in advanced rocket technologies and power requirements for space launches.
aquitaine
Ok, so we've all been hearing about the VASIMIR in recent years. If we were to use something like that to lift something off of the Earth (like or rocket or horizontally like a jet), how much power would it need? I'm guessing an order of magnitude more than the 200kW version currently being developed for space only purposes.
VASIMR has high specific impulse and therefore low thrust to power ratio. To lift a meager 1 ton spacecraft off the surface of the planet, you need thrust of 10^4 Newton. Assuming specific impulse of 3000 s (exhaust velocity 30 km/s, on the low end for VASIMR), you need W = T*v/2 = 15 megawatt.
  • · Replies 35 ·
  • · Replies 0 ·
