Particle Nature of Light versus Compton Scattering Effect
The discussion centers on the particle nature of light, specifically examining the Compton scattering effect and its implications for wave-particle duality. Participants explore various phenomena that may indicate light's particle-like behavior, as well as alternative explanations for these effects.
  • Some participants argue that the Compton scattering effect is a primary piece of evidence for light's particle-like behavior and inquire about other supporting effects.
  • Others propose that if an alternative explanation for Compton scattering exists, such as a relativistic Doppler effect, it could challenge the wave-particle duality of light.
  • One participant mentions the photoelectric effect as another phenomenon supporting the particle nature of light, asserting that it requires light to have particle characteristics to displace electrons.
  • Another participant counters the necessity of assuming light behaves as particles, suggesting that energy can displace electrons without requiring a particle model.
  • The blackbody spectrum is cited as evidence that cannot be explained by classical electromagnetic wave theory, supporting the particle aspect of light through the relationship E=hf.
Participants express differing views on the necessity of a particle model for light, with some supporting the particle nature through various effects while others challenge this perspective, suggesting alternative explanations. The discussion remains unresolved with multiple competing views present.
Participants highlight limitations in the explanations of phenomena like the photoelectric effect and blackbody radiation, noting dependencies on specific conditions such as frequency and energy levels, which remain unresolved.
what_are_electrons
The Compton scattering effect (1923) seems to be the main evidence that light has a particle-like behavior. What are the other effects that indicate that light has a particle-like behavior?
If there are no other effects that indicate that light has a particle-like behavior, and if we find an alternate explanation for the observed Compton scattering effect, then we would have eliminated the wave-particle duality of light.
Andrew Gray has commented that the Compton scattering effect can be explained as a (relativistic) Doppler effect on a wave.
If Compton scattering can be explained this way, and there is no other evidence for the particle nature, then we can focus on the wave nature of light, and eliminate the dichotomy.
Yes there is, what about the Photoelecric effect. This is another particle nature of light, since light at a high enough energy can displace an electron out of its orbit. In order to do this, you need a particle.
Nenad said:
( snip ) can displace an electron out of its orbit. In order to do this, you need a particle.
I don't see how that is so. Adding most any kind of energy to mass will displace electrons. Isee no need to assume that the energy comes in the form of particles.
Vern
The blackbody spectrum is another thing that cannot be explained by treating light as a classical EM wave. As for the photoelectric effect, the problem there is that light of a certain frequency or higher is needed to displace the electron - cranking up the beam intensity will not do it. All of these experiments provide support for the formula E=hf which is the basis of the particle aspect of light.
  • · Replies 36 ·
10K
