Basic calculus 1 question: What is the defining formula of sinΘ?
The discussion revolves around deriving the derivative of the sine function, sin(Θ), using the definition of differentiation. Participants are engaged in a calculus context, specifically focusing on the application of limits and trigonometric identities.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss substituting values into the differentiation formula and explore the use of trigonometric identities. There are attempts to clarify the correct limits and expressions needed for the derivation.
The discussion is active, with participants providing guidance on the necessary steps and identities to use. Some participants are questioning the setup of the limit and the terms involved, while others are reflecting on their understanding and progress.
There is mention of confusion regarding the correct application of limits and the notation used, as well as the need to recall specific trigonometric limits. Participants are also navigating the challenge of using different variables for clarity.
Arshad_Physic
Q) Derive the dereitvative of sinΘ using the definition of differentiation.
I am in Calculus 3, and I used to know how to work this problem very well! :) I just don't remember lol - I just need a little help I guess! :)
lim [f(x+h) - f(x))]/h
x→0
f(x) = sinΘ
f(x+h) = (sinΘ + h)
Now I am STUCK! lol
THanks in Advance! :)
well now put that into the formula and check the numerator.
You will have sin(θ+h)-sinθ. Do you know your sum to product formulas? These will help greatly here or you can expand sin(θ+h) as well.
x→0
f(x) = sinΘ
f(x+h) = (sinΘ + h)
Now I am STUCK! lol
Might as well use x instead of theta, since x is easier to type.
f(x + h) = sin(x + h)
Use the identity for the sine of the sum of two angles.
You will also need a limit:
[tex]\lim_{h \to 0} \frac{sin(h)}{h}[/tex]
Do you remember the value of this limit?
so, I write:
lim [sin(x+h) - sin(x))]/h
x→0
So, I get:
lim [sin(x) cos(h) + cos(x)sin(h) - sin(x))]/h
x→0
But now I am stuck again lol - I understand that if I use [tex]\lim_{h \to 0} \frac{sin(h)}{h}[/tex]
then my equation should become:
lim [sin(x) cos(h) + cos(x)sin(h) ]/h , right?
x→0
Your limit should be as h --> 0, not as x --> 0. Also, you are missing a term in the numerator. What happened to the -sin(x) that used to be there?
There's another limit that you'll need as well:
[tex]\lim_{h \to 0} \frac{cos(h) - 1}{h}[/tex]
Took me a while for me to figure this out! I spent time expanding on the ideas both of you gave me and finally understood what to do!
THANKS to BOTH of you! :)
