Solving Induction Proof for Positive Integers: Step-by-Step Guide
  • Thread starter Thread starter scottstapp
    Induction Proof
The discussion revolves around a proof by induction concerning the summation of the series \(\sum \frac{1}{k(k+1)}\) for positive integers \(n\), with the goal of demonstrating that it equals \(\frac{n}{n+1}\). Participants explore the structure and justification of their proofs, referencing related mathematical concepts.
  • Participants discuss the initial setup of the proof and the justification of including specific terms in the summation. There are inquiries about the validity of steps taken, particularly regarding the inclusion of the base case and the transition from \(n\) to \(n+1\). Some suggest using partial fractions to simplify the summation.
The conversation is ongoing, with participants providing insights into their reasoning and algebraic manipulations. There is a recognition of the connection between different representations of the summation, though no consensus has been reached on the clarity of certain steps. Guidance has been offered regarding the structure of the proof and alternative methods of approach.
Participants are navigating the complexities of proof by induction, with some expressing uncertainty about specific algebraic steps and the implications of their assumptions. The discussion reflects a learning environment where foundational concepts are being examined and clarified.
scottstapp
This is my first proof by induction so I need some assistance
If n is a positive integer, then [tex]\sum1/(k(k+1))[/tex]from k=1 to n is equal to n/(n+1)
I'm not sure if this is useful for this proof but we are given the proposition:
let n be a positive integer. Then the sum of the first n positive integers is equal to (n(n+1))/2.
(1) Let S be the set of all positive integers k such that 1/2+1/6+...+1/k(k+1)= n/(n+1)
(2) 1 is in S because 1/1(1+1)=1/2 which is in S (not sure if this is the correct approach)
(3) Let n be any element of S and let t=n+1
Am I on the right track? For my next step would I just substitute t=n+1 and solve?
Thanks
Try decomposing
[tex] \frac{1}{k(k+1)}[/tex]
into partial fractions, and writing your original sum in terms of those partial fractions.
Thank you statdad I believe this helped but am still curious about my step (2).
Here is what I have changed:
(1)Let S be the set of all positive integers k such that 1/2+(1/2)(1/3)+...+(1/k)(k+1)= n/(n+1)
(2) 1 is in S because (1/1)(1/2)=1/2 which is in S (not sure if this is the correct approach)
(4) (1/1)(1/2)+(1/2)(1/3)+...+(1/n)(1/n+1)+(1/t)(1/t+1)=(n/(n+1))+(1/t)(1/t+1)
(5) n=t-1
(6) Substituting this into the right hand side leads to: t/(t+1)
I'm pretty sure that's the way to do it I did the algebra for step 6 but did not want to include all the steps. Is (2) correctly justified?
Thanks again
Step (2) in your proof is hard to argue with. There's only one term in the sum which is 1/(1*2) And your formula for the sum of the series F(n)=n/(n+1) is also 1/2. I'm not really following what you did for the other steps. You want to prove F(n+1)-F(n)=1/((n+1)*(n+2)), right? Since that's the extra term you added on to the series. I'm pretty unclear on what algebra you actually did. BTW statdad was pointing out a noninductive way to prove it using telescoping series.
No, I do not want to prove F(n+1)-F(n)=1/((n+1)*(n+2)).
Here is my algebra for my last step, maybe it will clarify things:
once we let n=t-1 and plug it into (n/(n+1))+(1/t)(1/t+1) we get the following:
((t-1)/t)+(1/(t(t+1))) finding a common denominator gives ((t+1)(t-1)+1)/(t(t+1))
Multiplying out the numerator gives t2/(t(t+1))
A t in the numerator and denominator cancel giving t/(t+1)
Therefore t is in the form we are looking to prove therefore meaning that t=n+1 exists in S.
Does this make sense now?
Ah, I see. Your n/(n+1) is my F(n). Your (1/t)(1/t+1) is my 1/((n+1)*(n+2)). Your t/(t+1) is my F(n+1). So you've proved F(n)+1/((n+1)*(n+2))=F(n+1). Same thing. Sorry, I think the t was throwing me off.
