Find the work done on a box on an inclined plane
The work done on a box by a constant force of 85.0 N, applied at an angle of 53.0° on a frictionless ramp, is calculated using the formula for work, W = F dot D. The vertical distance moved by the box is 0.45 m. The correct calculation reveals that the work done is 17.658 J, which corresponds to the increase in potential energy of the box, calculated as m*g*h, where m is the mass (4.0 kg) and g is the acceleration due to gravity (9.81 m/s²).
  • Understanding of basic physics concepts such as work and energy
  • Familiarity with vector components and dot product calculations
  • Knowledge of gravitational potential energy formula: PE = m*g*h
  • Ability to interpret and apply trigonometric functions in physics problems
  • Study the concept of work-energy theorem in physics
  • Learn about vector decomposition and its applications in physics
  • Explore gravitational potential energy and its implications in various scenarios
  • Investigate the effects of friction on work done in inclined plane problems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of work done on objects on inclined planes.
popo902
a constant force Fa of magnitude 85.0 N is applied to a 4.0 kg shoe box at angle φ = 53.0°, causing the box to move up a frictionless ramp at constant speed. How much work is done on the box by Fa when the box has moved through vertical distance h = 0.45 m?
heres the picture to explain where the phi comes from http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c07/pict_7_32.gif
W=F dot D
or W = FDcostheta
i know that if an object is going at constant speed it's net force is zero
i tried solving for D which gave me .45/sintheta
then i got y comp of the weight force = 4gsinthet
the x comp of the wieght cut the phi angle in two = 53 - theta
and using Fa and angle (53-thet) i got the force that balance the 4g sin = 85sin(53 - thet)
then i used 4g sinthet = 85sin(53 - thet) to find theta because the net force is zero
i then put the theta i got into the D equation above.
I then found the x and y components of D and the x and y compnents of F using the angle( 53-thet) and did the dot product of that which came out to be 59.51455753 J
and it's wrong...
the answer is 17.658 J...supposedly
can someone tell me what I'm doing wrong? am i using the wrong angle or am i just going abot the problem wrong from the beginning? help please
When the work is done on a body, its kinetic energy increases. But in the problem it is stated that the box moves with uniform velocity. How is that?
Next the work done on the box = rise in potential energy of the box = m*g*h
If you substitute the values you get the answer.
