Wave equations and Schrodinger's equation
The discussion revolves around the nature of waves, particularly in the context of quantum mechanics and the Schrödinger equation. Participants explore conceptual questions about wave behavior, wave functions, and the mathematical representation of waves, including sine and cosine functions. The scope includes theoretical and conceptual aspects of wave motion and quantum mechanics.
  • Some participants express confusion about the fundamental nature of waves and what it means for energy to travel as a wave.
  • There is a discussion about how the wave function characterizes motion and whether it represents a slice of the wave's behavior in all directions.
  • Questions are raised regarding the relationship between amplitude, wavelength, and energy, including what factors influence changes in these properties.
  • Participants inquire why sine and cosine functions are used to describe waves and how these functions capture oscillatory behavior.
  • One participant suggests that the amplitude of a wave is related to the energy it carries, using the analogy of a boat on the ocean.
  • There is a question about the meaning of the components in the wave function equation and whether frequency represents decay in quantum contexts.
  • Some participants discuss the implications of holding position or time constant in the Schrödinger equation and how this affects the representation of the wave function.
Participants generally express confusion and seek clarification on various aspects of wave behavior and the mathematical representation of waves. Multiple competing views and interpretations remain, particularly regarding the nature of wave functions and the implications of the Schrödinger equation.
Some limitations in understanding are noted, including a weak mathematical foundation among participants, which may affect their grasp of the concepts discussed. There are unresolved questions about the nature of decay in quantum mechanics and the specific roles of amplitude and wavelength.
avocadogirl
I'm having some difficulty with quantum which stems from a weak math background as a shaky foundation upon which to start with an inherently difficult subject. So, if anyone would be willing to help me with some conceptual obstacles and thought exercises, I would be very grateful. These are not course questions or assigned problem work, they are questions I find I am asking myself as I read through my textbook and flounder in confusion.
What is a wave? What does this motion really mean, in physical terms? What does it mean for energy to travel in such a manner? When you have something that is traveling as a wave, and you characterize it with a wave function, are you looking at one slice of the motion because the energy is actually traveling with this wave characteristic in 360 degrees? Is this wave pattern how it behaves in every direction, and the only thing that is unique to a given energy is wavelength and amplitude? Why do wavelength and amplitude change and what affects this change? What changes amplitude and what changes wavelength?
Why do sine and cosine functions describe waves? Why do they describe every kind of wave motion possible? How do they describe waves? How does the sine or cosine function work such that it captures the behavior of something that oscillates and, what causes things to oscillate in this manner?
From all of this, if you have Acos( ((2pi)x/lambda) - ((2pi)frequency*time)), what do each of these components mean? Is the component involving frequency a decay of the oscillation? Do you have to even consider decay in quantum? Is this a nonsensical question? If you do consider a decay, is the decay representative of factors which change wave functions of particles as they change energy states?
Is the wave function always of the form Acos(((2pi)x/lambda) - ((2pi)frequency*time))? Do you ever use sine instead of cosine?
When you say that the Schrödinger wave equation is a function of position and time but, you can hold one or the other constant to take the equation to be a function of either position or time, what does that mean? The text represents a cosine wave if position is on the x-axis and psi, the wave equation, is on the y axis, while time is constant, but, it shows only arrows propagating along the y axis, marked to indicate psi, the wave equation, when position is held constant and time is varied. (Quantum Mechanics, An Accessible Introduction. Robert Scherrer) I don't understand what this means, how it works that way, or why it works.
If anyone can offer me a dumbed-down explanation of the wave equation, or wave equations in general, I would really appreciate it.
Sincere thanks.
M.
The energy in a wave is related to the amplitude. If an object follows a wave as the wave goes by the object moves back and forth, like a boat on the ocean.
The energy is always measured as the movement perpendicular to the direction the wave is traveling. Again think of the boat on the ocean example.
The sine or cosine of any number gives you a number from -1 to 1. In this way a variable will give you a wave of unit amplitude. Simply multiply this function by a factor A to give it an amplitude. 10*cos(x) gives you a wave with amplitude of 10.This will blow your mind
http://ocw.mit.edu/OcwWeb/Physics/8-03Fall-2004/VideoLectures/
But, only some things travel perpendicular to the direction of propagation, correct? Doesn't light travel in 360 degrees?
Well, I guess even taking one segment of infinitely many they are all planes perpendicular to the propagation of motion. I'm sorry. My momentary misunderstanding.
Thank you, lost conjugate. It is much appreciated.
Sincere thanks.
M.
Wave motion is a way to transfer energy through a continuous elastic medium without the transfer of mass. The continuum vibrates with a given frequency as the energy passes through it. The frequency is given by the source, while the wave speed and the wavelength are characteristics of the supporting medium. The wave function gives the displacement of the vibrating medium and the amplitude is the maximum displacement.
Sine and cosine functions “describe waves” because they are solutions of the wave equation, which describes all kinds of mechanical waves as well as electromagnetic waves. For example, [tex]y = ACos({\textstyle{{2\pi x} \over \lambda }} - 2\pi ft)[/tex] might be the displacement of a vibrating string. But, a wavefunction can have different forms. The actual form of the wavefunction for the vibrating string depends on how we start it; we can pluck it in various ways or we could hit it with a hammer or we can connect one end to a tuning fork. (I remember doing this in freshman lab.)
Imagine a piece of tape at position x. Then [tex]y = ACos(const - 2\pi ft)[/tex] gives the displacement of the piece of tape as it vibrates in the y-direction. If we hold t constant, then [tex]y = ACos({\textstyle{{2\pi x} \over \lambda }} - const)[/tex] gives the shape of the entire string at time t. The component involving frequency has nothing to do with decay. A decaying wavefunction would look like [tex]y = A(t)Cos({\textstyle{{2\pi x} \over\lambda }} - 2\pi ft)[/tex] where A(t) is a decreasing function of time.
The Schrödinger equation is not really a wave equation. In one dimension, the wave equation is [tex]{{d^2 y} \over {d t^2}} = v^2 {{d^2 y} \over {d x^2}}[/tex] while the Schrödinger equation, in its simplest form, is [tex]i\hbar {\textstyle{{d\psi } \over {dt}}} = - {\textstyle{{\hbar ^2 } \over {2m}}}{\textstyle{{d^2 \psi } \over {dx^2 }}}[/tex]. The Schrödinger equation is first order in time while the wave equation is second order in time. Note, also, that [tex]\psi (x,t)[/tex] is necessarily complex. A real function like [tex]y = ACos({{2\pi x} \over \lambda } - 2\pi ft)[/tex] is not a solution of the Schrödinger equation. [tex]\psi (x,t)[/tex] is used to calculate probabilities, so some people call them probability waves. As far as we know, Schrödinger waves are strictly mathematical and there is no vibrating medium.
I am not familiar with Scherrer’s text, but I did find that his section 3.2 The Meaning of the Wave Function
might answer your questions.
Best wishes.
There are 2 types of waves, longitudinal e.g sound, and transverse e.g light , water waves, waves on a string. Light will travel in all directions which is not 360 degrees, since we are talking about 3 dimensional propagation.
Imagine a piece of string bent into a shape. It doesn't matter what the shape is; it doesn't have to be sine or cosine. Imagine it traveling in a certain direction. That's a wave.
Thank you, all. Your time and help is immensely appreciated.
  • · Replies 39 ·
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 17 ·
