Hall Effect Experimental Results Issue
The forum discussion addresses issues encountered during a Hall effect experiment involving a solenoid and a Hall probe. The experiment revealed a slight negative potential at low solenoid current values, attributed to residual magnetic fields or offset voltages in the voltmeter. Additionally, discrepancies in Helmholtz coil results were noted, potentially due to wiring mistakes, calibration errors, or improper placement of the Hall probe. These factors highlight the importance of meticulous setup and calibration in experimental physics.
  • Understanding of Hall effect principles
  • Familiarity with solenoid and Hall probe configurations
  • Knowledge of voltmeter calibration techniques
  • Experience with Helmholtz coil setups
  • Investigate Hall effect probe sensitivity to magnetic fields
  • Research proper calibration methods for voltmeters
  • Learn about common wiring mistakes in experimental setups
  • Study the correct placement techniques for Hall probes in coils
Physics students, experimental physicists, and educators involved in electromagnetism experiments will benefit from this discussion.
K29
One of the simple experiments for simply observing Hall effect was done. However, I have a problem with the experimental results (attached .xls)
First the current in the solenoid was varied while the current in the Hall Probe was constant. Then the current in the Hall Probe was varied while the solenoid current was kept constant.
1.) (Ignore the Helmholz for now)Looking at the left most table. There is a slight negative potential for the low solenoid current values. When the solenoid current was set to 0, and the Hall probe was switched on there was this small negative voltage. There is nothing wrong with the calibration of the voltmeter, as when the current is decreased to 0, the negative potential slowly vanishes. What causes this?
2.) I am trying to identify the mistake made with the Helmholz results. The cables were never switched around at any time. What is going on here? It is possible that we accidentally flipped the Hall Probe over before doing the last Helmholz results, but this would simply result in the Hall Voltages to have a change in sign, not to go in entirely the wrong direction!
Please help. Thanks in advance.
1.) The small negative potential when the solenoid current is set to 0 may be caused by a few different factors. It could be due to the fact that the Hall effect probe is sensitive to magnetic fields and when the solenoid current is set to 0, there is still a residual magnetic field present in the area. It could also be due to a small offset voltage present in the voltmeter being used. 2.) The results from the Helmholz coils are likely incorrect due to either a wiring mistake or a calibration error. If the cables were switched around at any point, this could have caused the readings to be off. Additionally, if the calibration of the voltmeter was not done correctly, this could also lead to incorrect results. It is also possible that the Hall Probe was not placed correctly in the coil when the measurements were taken, resulting in an incorrect reading.
  • · Replies 0 ·
  • · Replies 0 ·
