How to Prove a Trigonometric Identity
  • Thread starter Thread starter chenny1
    identities Trig
To prove a trigonometric identity, one must demonstrate that the statement holds true for all values of the variable involved. The discussion highlights the identity cos(θ) = sin(π/2 - θ) and emphasizes the need to manipulate one side of the equation to show it equals the other. Participants clarify that establishing an identity involves using known trigonometric identities and consistent notation. An example is provided to illustrate the process of proving an identity by starting with the more complex side. Ultimately, understanding the requirements of proving identities is essential for success in trigonometry.
chenny1
cos = sin (pi/2-theta)
What have you tried? You need to show an attempt at a solution before anyone can help you out. What trig identities do you know?
Wait. I'm just asking one question.
The trig identity I was trying to use was cos = sin (pi/2-theta).
I'm sorry, I haven't taken trig for along time and I'm just trying to brush up for my admissions test. I'm not too positive what it is asking when it states establish an identity. Am I suppose to prove it?
chenny1 said:
1. Establish the identity sin(3pi/2-theta) = - cos theta
2. cos = sin (pi/2-theta)
3. sin (3pi/2-theta = - sin (pi/2-theta)
Establishing an identity means proving that it is a true statement for all values of the variable. Your numbered statements threw me off. I thought you were asking how to prove three statements.
To prove an identity, you genearlly want to start with one side and use identities to manipulate it, showing that it is the same as the other side.
Work with sin(3pi/2 - theta), using the identity for sine of the difference of two angles. You will also need to know the values of the sine and cosine functions at a specific angle.
Be sure to include the angle, and be consistent in your use of parentheses. In #2 you cos, which is just the name of the function. In #3, you're missing a right parenthesis.
Here's an example of proving an identity.
Show that (x + 2)2 - (x - 2)2 = 8x, for all x.
It's usually a good idea to start with the side that seems most complicated.
(x + 2)2 - (x - 2)2 = x2 + 4x + 4 - (x2 - 4x + 4) = x2 + 4x + 4 - x2 + 4x - 4 = 4x + 4x = 8x.
This shows that (x + 2)2 - (x - 2)2 = 8x. Since there are no restrictions on x in any step, this is an identity that is true for all values of x.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
