Can I do expectation like this
  • Thread starter Thread starter aegea
    Expectation
The discussion focuses on calculating the expected value of a transformed normal variable, specifically E(y) where y = 160*x^2 and x follows a normal distribution x ~ N(a, b). The correct approach is to utilize the linearity of expectation, leading to E(y) = 160*E(X^2). Additionally, the variance formula V(X) = E(X^2) - [E(X)]^2 is highlighted as a crucial concept in this calculation. The participants confirm that substituting the density function of x directly into the integral is valid but may complicate the process unnecessarily.
  • Understanding of normal distribution, specifically x ~ N(a, b)
  • Knowledge of expected value and its properties
  • Familiarity with variance calculations, including V(X) = E(X^2) - [E(X)]^2
  • Basic integration techniques for probability density functions
  • Study the properties of linear operators in expectation calculations
  • Learn about transformations of random variables and their expected values
  • Explore the derivation and application of the variance formula in statistics
  • Investigate advanced integration techniques for probability distributions
Statisticians, data analysts, and students in probability theory who are working with normal distributions and expected value calculations.
aegea
Many thanks in advance
Suppose x is normal variable x~N(a,b)
and y=160*x^2
I need calculate E(y)=∫yf(y)d(y)
f(y) is the density function of y
how can I write it as an integral of x since we know x's distribution, I mean use the density function of x to substitute the original integral
Can I just use E(y)=E(160 x^2)= ∫ 160 x^2 f(x) d(x)
then I can use f(x), which is the density function of normal.
Seems right, but seems wrong, seems I use f(x) to substitute x directly!
You can do it the way you suggested (it is logically correct), but I believe it will make more work for yourself (but I didn't look at it because there is a cleaner way).
Here are a few hints that should help:
Remember that the expected value function is a linear operator so
[tex]E(Y)=E(160X^2)=160E(X^2)[/tex]
and
[tex]V(X)=E(X^2)-[E(X)]^2[/tex]
  • · Replies 18 ·
