Force Pushing a Block on a Rough Surface
The discussion focuses on calculating the work done on a block sliding on a rough surface under the influence of a force P of 2.0 N at an angle of 40 degrees. The kinetic energies at points A and B are 5.0 J and 4.0 J, respectively, indicating a net change of -1.0 J. The work-energy theorem is applied to determine the work done by the force P and the force of friction, with the coefficient of kinetic friction given as 0.7. The mass of the block can be derived from these calculations.
  • Understanding of the work-energy theorem
  • Knowledge of kinetic energy equations
  • Familiarity with forces and friction concepts
  • Ability to perform vector decomposition of forces
  • Calculate work done by a force using the formula W = F * d * cos(θ)
  • Explore the work-energy theorem in detail
  • Learn about vector decomposition in physics
  • Investigate the effects of friction on motion in various scenarios
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of work and energy problems involving friction.
mecablaze
A block of mass m slides on a rough horizontal surface from point A to point B. A force (magnitude P = 2.0 N) acts on the block between A and B. P acts on the block at 40 degrees above the horizontal. Points A and B are 1.5 meters apart. If the kinetic energies of the block at A and B are 5.0 J and 4.0 J, respectively.
a) How much work is done on the block by the force P as it moves from A to B
b) How much work is done on the block by the force of friction as the block moves from A to B
c) If the coefficient of kinetic friction is 0.7, what is the mass m?
kinetic energy = 0.5 * m * v2
horizontal force on the block = cos(40 degrees) * 2.0 N
Well, I reasoned that the net change in kinetic energy is -1.0 J from A to B. We divide that by the change in distance so the net force acting on the block from A to B is -1.0/1.5 Newtons. Part of that is due to friction ([tex]\mu[/tex]*(mg + vertical component of P)) and part of it is due to the horizontal component of P. Obviously, since the kinetic energy is decreasing, the force due to friction is greater than the horizontal component of P.
The net force on the block is the sum of the two horizontal force vectors. I just don't know how to split them up and get parts a) and b)
edit: formatting
from this, you can calculate the work done by P in part (a).
check your plus/minus sign in your equation for friction force
yes
You are going about the problem out of sequence. You can calculate the work done by P directly, for part a, then use the work energy theorem to calculate the work done by friction, for part b. Then correct your friction force equation to solve for m in part c.
  • · Replies 20 ·
