| Thread Closed |
Beam Design Question? |
Share Thread | Thread Tools |
| Mar5-10, 02:24 PM | #1 |
for one of my drafting classes I have to design a beam. The beam needs to carry a concentrated load at the midpoint.
some parameters: 4ft span total materials must weigh under 12oz Pin reactions at the ends the person last year that won(highest load) made a simple I joist out of Balsa. I'm wondering if anyone has any experience in this project. I am thinking of making a Vtype webtruss out of pine, I know mod. of Elasticity for pine is greater than balsa, but more dense which I may run into problems with the weight. Any suggestions? |
| Mar5-10, 05:36 PM | #2 |
Pin reactions at both ends?
| Mar5-10, 09:23 PM | #3 |
sorry, simply supported rigid beam, reaction only in the y direction, no x or moment
| Mar6-10, 03:17 AM | #4 |
Castellated beam or box?
| Mar13-10, 04:33 AM | #5 |
hils0005: a couple things to consider.
How is it loaded, will it be 4point or 2 point bending, if 4point and region of constant moment midspan on a 4ft span a 'V' might see a quicker load path but have higher stress do to the off center applied loading. Why a simple I section is so effective is because it's maximizing 2nd moment of area while minimizing connections. Your truss system may theoretically have a higher capacity but the constructability of all those pieces joining increases your chances of never seeing the full loading potential simply because of how it was made. Recommendation: if there are no material restrictions get a hold of some Fiber Reinforced Polymer wrap and make another simple I section, but epoxy the wrap to your section. Making sure the direction of the fiber matches the principal plane of loading. FRP is very light and could be cut, if you find your I section is getting close to the 12oz marker and can't wrap the entire member, wrap the critical sections specifically the two web members. Hope this helps. |
| Mar17-10, 11:14 PM | #6 |
Try this site:
http://www.dragonplate.com/ecart/categories.asp?cID=84 They actually sell carbon fiber I-beams and a lot of other stuff. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Beam Design Question?
| I-Beam load capacity question, what beam for 70 tons? | General Engineering | 1 | ||
| [Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ? | Mechanical Engineering | 2 | ||
| I beam design | General Engineering | 2 | ||
| Do you calculate the amount of load a beam can take based on when the beam cracks? | Materials & Chemical Engineering | 6 | ||
| I-beam Design | General Engineering | 2 | ||
