Finding Derivatives: Power Rule vs Chain Rule
The discussion revolves around the differentiation of functions using the power rule and the chain rule in calculus. Participants explore when to apply each rule, the relationship between them, and provide examples to illustrate their points. The scope includes conceptual understanding and practical application of these differentiation techniques.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant asks how to determine when to use the power rule versus the chain rule for finding derivatives.
  • Another participant explains that the chain rule is applied when differentiating composite functions and suggests that the power rule can be seen as a simpler case of the chain rule.
  • Some participants propose that the power rule is applicable when the function is in the form f(x)=ax^n, while the chain rule is preferred for composite functions, such as f(x)=a(x+3)^n.
  • One participant argues that the power rule is derived from first principles, while others suggest that it is easier to use the power rule for straightforward derivatives.
  • Another participant emphasizes that the chain rule can be applied to any composition of functions, while the power rule is a specific case where the outer function is a power.
Participants express differing views on the relationship between the power rule and the chain rule, with some suggesting that the power rule is a simpler application of the chain rule, while others maintain that they are distinct methods applicable in different contexts. The discussion remains unresolved regarding the best approach to use in various scenarios.
Some participants mention that understanding these rules requires practice and familiarity with different examples, indicating that there may be nuances in their application that are not fully explored in the discussion.
physicskid
In finding a derivative of a value, how do you know whether when to use the power rule or the chain rule? can anyone please tell me?
Usually any good calc textbook will walk you through the process. It's rather mechanical. If you have a function inside of another function, you differentiate the outside one and multiply it by the inside one. With the power rule, you are still using the chain rule without knowing it. For example, in differentiating the function
f(x) = x^2, you take the derivative of the "outside" (x^2) times the derivative of the "inside" (x) yielding f(x) = 2x*(1) . You multiply by one since the chain rule told you to multiply by the derivative of the inside function. I'm not sure if I answered your question, but you'd be better off taking a peek at a good calc textbook (try Stewarts), and working a few problems until you get it. It's really a skill you need to practice to understand how the rules apply.
If the equation is in the form f(x)=ax^n, then you can use the power rule. If it is a composite function of some form, you can use the chain rule to keep it simple. f(x)=a(x+3)^n can be expanded out and differentiated with the power rule, but it's much easier to use chain.
Although I believe that the power rule is more a derivation of first principles as opposed to application of the chain rule, you can use chain if you want to...but it's so much easier to use anx^n-1 (Power rule).
Its wery easy, there's no messing around. The power rule is basically the chain rule, but simpler and for easier derivatives.
Lets say we have a function
[tex]u(x) = kx^n[/tex]
[tex]\frac {d}{dx} u(x) = \frac {d(kx^n)}{dx}[/tex]
[tex]\frac {d}{dx} u(x) = (nk)x^{n-1}[/tex]
Now the chain rule. Let's say we have a function:
[tex]f(x) = (u(x))^n[/tex]
[tex]\frac {d}{dx} f(x) = \frac {d((u(x))^n)}{dx}[/tex]
[tex]\frac {d}{dx} f(x)= n(u(x))^n) \frac {d(u(x))}{dx}[/tex]
its a simple set of rules, the best way to get used to them is to practice different examples. Sorry if my notation at the end is a little funky, the latex notation is hard to work with.
the chain rule works on the composition of any two functions at all f(g(x)).
the power rule is the special case where the outer function is a power (g(x))^n,
i.e. here u = g(x) is anything, but f(u) = u^n.
