Current in a hollow tube problem
  • Thread starter Thread starter milkman9000
    Current Tube
The current in a 60.0-cm-long hollow nichrome tube with an inner diameter of 1.10 mm and an outer diameter of 4.20 mm connected to a 3.00 V battery can be calculated using the resistance formula R = ρ * L / A. The resistivity of nichrome is 1.5 x 10-6 ohm meters. The area A is determined by the formula A = π * (outer radius - inner radius)2. After calculating resistance, the current can be found using I = V / R.
  • Understanding of electrical resistance and Ohm's Law
  • Familiarity with the concept of resistivity
  • Ability to calculate the area of a circular cross-section
  • Knowledge of basic geometry for calculating inner and outer radii
  • Calculate the resistance of the hollow nichrome tube using R = ρ * L / A
  • Learn how to derive the area A for hollow cylindrical shapes
  • Explore the implications of resistivity in different materials
  • Study the effects of voltage on current in electrical circuits
Students studying physics, electrical engineers, and anyone interested in understanding current flow in conductive materials.
milkman9000
1. A 60.0 -cm-long hollow nichrome tube of inner diameter 1.10 mm, outer diameter 4.20 mm is connected to a 3.00 V battery. What is the current in the tube?
Resistivity for nichrome = 1.5*10^-6 ohm meters
I=V/R
E=V/L
I don't know what parts you are having trouble with, but before you can use the equations you posted you have to find the Resistance with the formula R=rho*L/A your A will be pi*(outer radius - inner radius)^2. Then you can proceed.
15K
  • · Replies 44 ·
  • · Replies 21 ·
12K
