| Thread Closed |
how to get an input matrix from user??? |
Share Thread |
| Mar8-10, 09:37 AM | #1 |
WITHOUT using the MATLAB ‘MULTIPLICATION COMMAND’ write down your own program to implement the matrix multiplication M = A*B, where A and B are two constant matrices of dimensions l x m and m x n, respectively. The program should:
Prompt the user to enter the dimensions l, m and n; Check if all the dimensions are positive integers and if this is not the case, ask the user to enter the values again; also to check whether multiplication is possible or not according the entered dimensions Prompt the user to enter the values of the two matrices; Apply matrix multiplication M = A * B and calculate the product M; Display the resultant matrix M [don’t use ‘;’ at end of statement in order to display]. PLZ help i m get stuck.... |
| Mar13-10, 04:40 PM | #2 |
What have you done so far?
| Thread Closed |
Similar discussions for: how to get an input matrix from user???
| ANSI Std. C++ Looping Menu while checking user input | Programming & Comp Sci | 7 | ||
| Record user input outside a program in c++. | Programming & Comp Sci | 0 | ||
| matlab user input variable name | Math & Science Software | 1 | ||
| Electrical and Computer Engineering, 2-input Look-Up tables designed with 2-input XOR | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Least squares Ridge Regression - how to do with solver that takes matrix input? | Linear & Abstract Algebra | 0 | ||
