Yet another doppler question (regarding conservation, time, and irradiance)
This discussion revolves around the Doppler effect, time dilation, and their implications for energy density and irradiance in the context of light sources. Participants explore the relationship between these concepts, particularly in scenarios involving moving light sources and observers, as well as the conservation of energy in these contexts.
  • One participant claims that the Doppler effect is equivalent to time dilation, suggesting that changes in energy density are due to light not experiencing time.
  • Another participant argues that the Doppler effect and time dilation are distinct phenomena, noting that time dilation always results in lower frequencies, while the Doppler effect can result in both higher and lower frequencies depending on the direction of motion.
  • Some participants question the concept of a photon's "self energy" and emphasize that energy conservation is maintained through the overall volume of fields decreasing.
  • A participant presents a numerical example to illustrate the difference between time dilation and the Doppler effect, explaining how the distance traveled by light pulses affects the timing of their reception by an observer.
  • There is a discussion about whether a fast-moving laser emits light at a different rate compared to a stationary laser, with some asserting that fewer photons are emitted per unit time while others highlight the effects of blueshift on energy received by an observer.
  • Participants express uncertainty about the implications of gravitational blueshifting and whether it results in a true energy gain.
Participants generally disagree on the relationship between the Doppler effect and time dilation, with multiple competing views presented. The discussion remains unresolved regarding the implications of these concepts on energy density and irradiance.
Some statements made by participants rely on specific definitions and assumptions that are not universally agreed upon, particularly regarding the nature of energy in the context of photons and the interpretation of time dilation.
ssope
I need the following statements logically-'spellchecked'. The internet, nor books will put it this simply, so I typed up what I feel is a summary, but I don't want to be incorrect in my own mind by doing so. So please proof read my logic and correct it for errors:
The doppler effect IS time dilation. However since light always travels at the same speed, the change in "time" is experienced in nature as a change in energy density of the beam of light, and this is because light does not experience time (otherwise it would decay). The only reason that the doppler effect has a special name in the case of light is because that Doppler fellow who discovered the frequency change for light was born back in the 1800's (before einstein's time).
The doppler effect says that by moving a light source towards an observer the observer will receive more energy per unit per time (because the energy is compressed). This apparent energy change does not violate the conservation of energy because the E in "E=hf" can be broken down into the photon's self energy and the photon's kinetic energy, in which case you subtract the appearant gain in energy due to the frequency change from the photon's self energy (meaning the kinetic energy increases at the same rate as the photon's self energy decreases).
{If correct}
How would I calculate the irradiance (change in flow of energy per unit per time). I'm guessing I'll need to know how fast the laser is moving, and what wattage the laser has, but let's say I have such values (if I'm missing any required input data, let me know).
Almost none of that is correct. The Doppler effect is not the same as time dilation, time dilation is always shifts towards lower frequencies and does not depend on direction, but the Doppler effect can shift higher or lower depending on the direction. Talking about what photons "experience" is mathematically ill-posed (involves division by 0). I don't know what a photon's self energy would be, but energy is conserved because the overall volume of the fields is decreasing.
Time dilation also shifts towards higher frequencies. High altitude clocks tick faster. You also did not correct and/or deal with some other statements in my post.
Yes, gravitational time dilation can be higher or lower, but is not really related to the Doppler effect. In SR, time dilation always shifts to lower frequencies and is sometimes called the transverse Doppler.
Which specific statement do you want me to correct?
ssope, are you aware that the classical Doppler shift is different than the relativistic Doppler shift? See here for the equations. And the difference is precisely because of the time dilation in the relativistic case! I gave a numerical example showing how it works in post #9 of this thread:
Suppose the source is sending out pulses once every 20 seconds in its own frame, and it's moving away from you at 0.6c. Then since its clock is slowed down by a factor of squareroot(1 - 0.6^2) = 0.8 in your frame due to time dilation, it will only be sending out pulses once every 20/0.8 = 25 seconds in your frame. That's just time dilation though, not the Doppler effect. The Doppler effect comes about because the source has moved farther away from you between each pulse, so the light from each pulse has a longer distance to travel to reach your eyes. For example, suppose at t=30 seconds in your frame the source was 100 light-seconds away from you and sent pulse #1, then 25 seconds later at t=55 seconds the source had moved 25*0.6c=15 light-seconds farther away from you so it was now 115 light-seconds away from you when it sent pulse #2. Since the first pulse takes 100 seconds between being emitted and reaching your eyes, it reaches your eyes at t=30+100=130 seconds; since the second pulse takes 115 seconds between being emitted and reaching your eyes, it reaches your eyes at t=55+115=170 seconds. So in spite of the fact that it's sending a pulse once every 25 seconds in your frame, the time between your seeing successive pulses is 170-130=40 seconds; that extra delay is the Doppler effect.
If you have a fast moving laser, does the laser and the wall its moving at experience time dilation but the light and the wall do not? Would the laser spit out light slower if it was moving fast?
DaleSpam said:
Yes, gravitational time dilation can be higher or lower, but is not really related to the Doppler effect. In SR, time dilation always shifts to lower frequencies and is sometimes called the transverse Doppler.Which specific statement do you want me to correct?
You didn't touch this:
It's not really meaningful to ask if the light "experiences" time dilation since light doesn't have any internal clock and in SR it doesn't have its own rest frame either. But in the inertial rest frame of any object moving slower than light, the light always moves at exactly c, never slower or faster, and any slower-than-light object that's not at rest in that frame (like a wall viewed in the in the rest frame of a laser emitter moving towards it, or the laser emitter viewed in the wall's rest frame) will experience time dilation.
Would the laser spit out less light per unit time if it was moving fast compared to a laser not moving?The doppler effect says that by moving a light source towards an observer the observer will receive more energy per unit per time (because the energy is compressed), yes? The doppler effect says that by moving a light source towards an observer the observer will receive more energy per unit per time (because the energy is compressed), yes?
Yes, fewer photons emitted per unit time and less energy emitted per unit time as well. Although if it's moving towards you, the blueshift will cause you to receive more photons/energy per unit time than you would from an identical laser emitter at rest relative to you, in spite of the fact that in your frame the laser emitter moving towards you is really emitting fewer photons/less energy per unit time than the one at rest relative to you.
Inituitivly, there should be a true energy gain associated with gravitational blueshifting, is this true?
There is a true gain in the amount of energy you receive per unit time, but not in the amount of energy being emitted per unit time in your rest frame. Here's an altered version of the numerical example I gave before:
Suppose the source is sending out pulses once every 20 seconds in its own frame, and it's moving towards you at 0.6c. Then since its clock is slowed down by a factor of squareroot(1 - 0.6^2) = 0.8 in your frame due to time dilation, it will only be sending out pulses once every 20/0.8 = 25 seconds in your frame. That's just time dilation though, not the Doppler effect. The Doppler effect comes about because the source has moved closer to you between each pulse, so the light from each pulse has a shorter distance to travel to reach your eyes. For example, suppose at t=30 seconds in your frame the source was 100 light-seconds away from you and sent pulse #1, then 25 seconds later at t=55 seconds the source had moved 25*0.6c=15 light-seconds closer you so it was now 85 light-seconds away from you when it sent pulse #2. Since the first pulse takes 100 seconds between being emitted and reaching your eyes, it reaches your eyes at t=30+100=130 seconds; since the second pulse takes 85 seconds between being emitted and reaching your eyes, it reaches your eyes at t=55+85=140 seconds. So in spite of the fact that it's sending a pulse once every 25 seconds in your frame, the time between your seeing successive pulses is 140-130=10 seconds; that shortened time is the Doppler effect.
So here the source is sending out new pulses once every 25 seconds in your frame, but you are receiving new pulses once every 10 seconds. So if each pulse contains a certain amount of energy, the rate at which you are receiving energy is higher than the rate at which it's actually being emitted in your frame.
Yes, I did.
That was referring to the usual Doppler. For the gravitational Doppler the extra EM energy comes from a decrease in gravitational PE.
What do you mean by "conserved" in this context? If the source was emitting bullets with equal kinetic energy in your frame, the rate at which you'd receive energy from the bullets would be higher than the rate in your frame at which the source was giving up potential energy to impart to the bullets, no? (obviously energy is still conserved in the sense that the total energy of source + you + bullets is constant over time) If so, would it be different for electromagnetic waves?
I was referring to the fields. E.g. see http://farside.ph.utexas.edu/teaching/em/lectures/node89.html" . The energy density in the volume between the emitter and reciever is constant, but the volume is decreasing. Therefore, more power must be leaving the volume than entering.
Got it, so it would be analogous to the bullet situation where the total energy of receiver + emitter + bullets flying in between them is staying constant from one moment to the next, but the receiver is receiving energy from bullets at a greater rate than the emitter is imparting energy to bullets (and since the distance between emitter and receiver is shrinking, the number of bullets in the air at any given moment, and thus the total energy of the bullets at that moment, is decreasing as well).
Yes, the two descriptions are perfectly compatible.
Why doesn't radioactive decay vary as a function of earth-sun distance. Why didn't the cassini spacecraft show such data? They had to correct tom-tom satilites for time dilation because of the low gravity, so why doesn't radioactive decay vary as a function of gravity? http://www.astroengine.com/?p=1382
All the measurements were done onboard, so you would not expect there to be any relativistic effects.
Are you saying because the onboard systems did not COMPARE themselves to Earth bound measurements that there is no question to be asked? Did you read the link?
Please answer both
What kind of variation would you expect here? Apparent variation due to different velocities relative to Earth (Doppler shift), or some kind of time dilation (gravitational or velocity-based)? Anyway, I would guess the graph of power output vs. time at the bottom of that page is using onboard time rather than Earth time (though the difference would probably be negligible), and certainly the power output was measured on board.
No, not due to velocities, the question is regarding due to gravitational changes. The varation I would expect is that plutonium would decay faster and faster the further it got away from the sun (and/or other gravitational fields)
Well, again, you wouldn't expect any changes whatsoever if the time axis is based on the ship's own clock. And if it's based on Earth clocks, I'd imagine any change in the decay rate due to the Earth being closer to the Sun and experiencing more gravitational time dilation would be totally miniscule, too small to make any appreciable difference. The Sun's Schwarzschild radius is about 3 kilometers, so according to the gravitational time dilation equation given here, a clock at radius r will be slowed down by a factor of [tex]\sqrt{1 - (3\,km)/r}[/tex] as compared with a clock at infinity. So, the ratio between tick rates of two clocks at r1 and r2 would be [tex]\frac{\sqrt{1 - (3\,km)/r_1}}{\sqrt{1 - (3\,km)/r_2}}[/tex]. The radius of the Earth's orbit is about 150 million kilometers, and the article says Cassini's decay rate was measured from 0.7 Earth radii to 1.7 Earth radii (about 105 to 255 million km), so I calculate the ratio of clock ticks at the two different distances to be about 0.9999999916 to 1. And even if you consider the ratio for a clock at the Earth's distance from the Sun (ignoring the gravitational time dilation from the Earth itself) and a clock infinitely far from the Sun, the ratio is still only 0.99999999 to 1.
I could use your help calculating the time difference for something orbiting very high above the moon in comparison to the surface of the Earth.
No. I am saying that the experimental answer to the question agrees with the theoretical prediction. From your previous comments it is pretty clear that you don't understand the theory, so you erroneously expected relativistic effects when there would be none.
Yes, and I read the arxiv paper it cited.
ssope said:
Please answer both
You are really pretty pushy.
Do you want to include both velocity-based and gravitational time dilation, or just the gravitational time dilation? And do you just want the clock to be at about the same distance as the moon, or do you actually want to include the contribution to gravitational time dilation from both the Earth and the moon? (if the latter I don't know enough about GR to be able to do that)
  • · Replies 17 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 46 ·
  • · Replies 18 ·
