Question related to Absolute Value
The discussion revolves around understanding the concept of absolute value, specifically comparing two expressions: |sqrt(2) - 1| and |1/2 - 1|. The original poster expresses confusion regarding why one expression is greater than the other, despite having a basic understanding of absolute values.
  • Participants explore the numerical values of the expressions involved, questioning the original poster's understanding of the absolute value function and its implications. Some participants suggest reviewing basic arithmetic and number properties.
The discussion includes attempts to clarify the original poster's confusion, with some participants providing numerical approximations and explanations of the absolute value function. There is an ongoing exploration of the conceptual difficulties faced by the original poster, with no explicit consensus reached.
Participants note that the original poster may need to revisit foundational concepts in arithmetic and number properties to better understand the comparison being made. There is an acknowledgment of the emotional tone in the responses, indicating a need for respectful communication in the learning process.
confusedabout
Hi everyone;
I've got this question concerning absolute value, although I understand the concept of absolute value, I can't quite understand why option B is bigger than option A.
I would really appreciate some explanation on the following question:
I am trying to post it in Latex, but in case that the comparison is not properly viewed, here is how it goes:
Option A
(everything inside absolute value symbol, the two vertical lines), sqrt2 - 1
Option B
1/2 - 1
I am getting very confused with something that appears to be simple and basic enough, do I need to review some other concepts? arithmetic and/or number properties? if so can someone pin point me to some web based explanations.
Thanks
And cheers to everyone
Huh? Are you asking whether
abs(sqrt(2) - 1) < abs(1/2 - 1)
Isn't it obvious?
If you can accept that sqrt(2) is a real between 1.41 and 1.42, you can see that
sqrt(2) - 1 < 1/2
sqrt(2) - 1 < abs(1/2 - 1)
Isn't it obvious?
sqrt(2) - 1 < 1/2
Excuse me...
First I signed to this forum to get help in a proper and educated way.
Secondly I ask that question because I have a doubt related to the concept.
I already know that 1.41 or 1.42 - 1 equals 0.41 or 0.42 I also know that 0.5 - 1 equals - 0.5
and I also know that the absolute value of a number is the value of a real number regarding the sign. that's why I ask that question, there's no need to be petulant, arrogant and/or try to belittle people here Tic-Tac...
Is been 20 years ago that I saw basic Algebra and I am trying to go back to school, so please have a little more of respect.
Plus your answer, doesn't help me at all from the conceptual point.
The absolute value is a function it's defined like this:
abs(x) = x, when x >= 0
abs(x) = -x, otherwise
You can calculate the right hand side in a straightforward way:
1/2 -1 = -1/2, so that means
abs(1/2 - 1) = -(-1/2) = 1/2
The right hand side is tricky because of the square root. But since we're dealing with inequalities and not interested in the exact number, we can abuse the fact that 1.41 < sqrt(2) < 1.42:
0.41 < sqrt(2) - 1 < 0.42
Since sqrt(2) - 1 is positive, it is equal to its own absolute value:
abs(sqrt(2) - 1) = sqrt(2) - 1, so
0.41 < abs(sqrt(2) - 1) < 0.42
And finally, since 0.42 < 1/2, we have
abs(sqrt(2) - 1) < 0.42 < 1/2, and
What steps do you get stuck on? What conceptual difficulties do you have over the absolute value function?
Option A
Option B
1/2 - 1
Sorry, confusedabout, but it's not at all clear what you're asking about.
You seem to be asking about why |√2 - 1| < |1/2 - 1|.
You accept that it obviously is, but you're not telling us why the obvious answer is bothering you. :confused:
As Tac-Tics :smile: says, what steps do you get stuck on? What conceptual difficulties do you have over the absolute value function?
confusedabout said:
Hi everyone;
Option A
Option B
1/2 - 1
Thanks
You seem to be asking whether |sqrt(2) - 1| < |1/2 - 1|. (Note that the | character is on the same key as the \ character.)
The left side is about 0.414. The right side is exactly 0.5.
The only thing the absolute value function does is return the magnitude (distance from 0) of the expression inside the vertical bars. There's really nothing very mysterious here.
There was nothing at all "arrogant" about tic-tacs response.
He assumed you know, or could use a calculator to find that [itex]\sqrt{2}[/itex] is about 1.414 and so [itex]\sqrt{2}- 1[/itex] is about .414. Then [math]|\sqrt{2}-1|[/math] is about .414.
1/2- 1 is, of course, -1/2= -.5 so |1/2- 1|= .5 and .414< .5. That is all he was saying and is a complete answer to your question.
  • · Replies 18 ·
